65 with inline six
Old Feb 26, 2014 | 05:43 AM
relayman53's Avatar
relayman53
65 with inline six
I put split hedders on my 65 with an inline six cylinder. Should i have a crossover pipe installed? Not a mechanic...bolt- on guy. Thanks in advance !
Old Feb 26, 2014 | 07:45 AM
my 66's Avatar
my 66
If its your everyday driver and you put the hedders on with flow throught mufflers for sound, i would not put a crossover pipe.
Old Feb 28, 2014 | 06:00 AM
peter sipp's Avatar
peter sipp
split exh mnflds
Hi relayman,
The whole point of the split exh mnflds is to aid the engines ability to have less back pressure. This will increase your mpg. If you put in a crossover pipe in the exh. this will increase the back pressure.
I drive a '65 F-100 with a 240 CI 6. GREAT engine. It has the stock one port exh exit. I have bought a set of split exh mnflds. I am in the process of putting them on. I am doing this for better mpg. On mine each exh mnfld will have its own pipe. No crossover.
So, tell me if you would a little about your truck.
Are you going to do anything to aid the carb's pre heating of the gas? Does(did) your engine pre heat the gas with the factory exh mnfld? What year is your truck?
Old Mar 1, 2014 | 07:17 PM
relayman53's Avatar
relayman53
my engine mods
[QUOTE=peter sipp;14116601]Hi relayman,
Are you going to do anything to aid the carb's pre heating of the gas? Does(did) your engine pre heat the gas with the factory exh mnfld? What year is your truck?[/QUOT
Mt truck is a 65
I installed hedders with flowmasters , Offenhauser aluminum intake, with a holley 390 cfm carb. I could instakk a carb baseplate under the intake and either pipe hot water through it..or tap into a couple of the hedders an use the exhaust gas to heat it but since i never opted to do that.
Old Mar 2, 2014 | 10:34 AM
peter sipp's Avatar
peter sipp
Headers for a 65 F-100, 240 cid 6.
Hi Relay man,
How does Ur truck sound with the headers now? I am going to give you my ph # so maybe you'd call me and let me listen to your set up? My # 828-280-4266, Thanks, Pete
mrad
Modular V10 (6.8l)
Jul 4, 2011 11:29 AM
ctango01
Apr 16, 2010 06:47 PM
PBR30
Modular V10 (6.8l)
15
Mar 28, 2010 05:08 PM
jlh_1
6.4L Power Stroke Diesel
Jun 26, 2008 08:14 PM
drumlinecowboy
May 7, 2005 11:03 PM
