Going to replace the ICP sensor. Questions?
Old Feb 24, 2014 | 07:53 PM
Firefighter 1406's Avatar
Firefighter 1406
Alright I have noticed that my ICP sensor has oil leaking. So I have been told to replace it before it goes out. Is the pigtail required after it leaks or only if the wires are damaged? I was probably going to order it through riffraff. Don't know much about the ICP so just trying to make sure I know what to do and replace.
Old Feb 24, 2014 | 08:04 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Spray the inside of the connector pins with a good electrical cleaner. No need to replace the plug unless it is damaged.
Old Feb 24, 2014 | 08:18 PM
Tailgate77478's Avatar
Tailgate77478
Do what Mike mentioned first. However, if you need a new ICP sensor, it is just the sensor itself. You need to make sure you keep the rubber gasket that fits on the pigtail connector that seats inside the ICP sensor itself (keeps debris out of the sensor). So, if you aren't experiencing any symptoms and you've cleaned it out, shop around for a good deal on a new ICP sensor (on eBay, RiffRaff, etc.). They're pricey (about $130) so shopping around for a good price is a luxury when possible.
Old Feb 24, 2014 | 08:28 PM
Firefighter 1406
That's what I will do. Tousley is at $130 and riffraff at $138. I would rather give my business to Clay. eBay was like $129.
Old Feb 24, 2014 | 08:30 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Did you check with DieselOrings?
Old Feb 24, 2014 | 09:04 PM
Firefighter 1406
Nope haven't checked there. Will do though.
$142 but they do have free shipping
On a side note. Is it the grey CPS sensor that everybody says to get? I can never remember.
Old Feb 24, 2014 | 09:15 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
grey CPS is the only OEM available now as far as I know. You can get the aftermarket black one that is notoriously unreliable as well.
Old Feb 25, 2014 | 06:28 AM
Tugly's Avatar
Tugly
Clay has the blue one, it's the "tweener" that does a good job. The black one is the smoothest-running, but the reliability is the concern.
Old Feb 25, 2014 | 07:08 AM
Firefighter 1406
I was just wondering. I have a spare CPS in the truck but it is a aftermarket BWD brand. I am sure it will work in a pinch but if I am ordering a ICP I may as well order a new CPS for the truck. Just reading more and more about using OEM sensors.
Flynman
Jul 28, 2020 08:49 PM
MONAVIERONJON
Jun 17, 2013 08:06 PM
JOHN2001
Aug 9, 2012 09:21 PM
timmyboy76
Oct 6, 2011 02:05 PM
Sparkplugless
36
May 22, 2009 05:52 AM
