Spider assy sensor
Old Oct 6, 2011 | 12:13 AM
timmyboy76's Avatar
timmyboy76
Spider assy sensor
What exactly is that sensor called? The one located at the bottom of the spider, that most people unplug. Can that sensor be removed, put a plug in its placed, and used somewhere else on the motor, to replace a bad sensor, if the spider sensor is good?
Old Oct 6, 2011 | 12:29 AM
hotroddsl's Avatar
hotroddsl
I think you are talking abought the AIT ( air intake temprature) that is nessecary for proper IDM function, the one every on disconnects is the EBPV on the pedestal it's below the spider you should put a resistor in it's place to avoid soft codes icant remember the value Radio Shack has them 5 for $3.99. The plug can be used for replacing the IPR if nessecary
Jim & fat Monty
Old Oct 6, 2011 | 07:19 AM
mueckster's Avatar
mueckster
Originally Posted by hotroddsl
I think you are talking abought the AIT ( air intake temprature) that is nessecary for proper IDM function, the one every on disconnects is the EBPV on the pedestal it's below the spider you should put a resistor in it's place to avoid soft codes icant remember the value Radio Shack has them 5 for $3.99. The plug can be used for replacing the IPR if nessecaryJim & fat Monty
470 ohm.....Can be used when deleting AIH and Wastegate Solenoid also.
Good idea!
Old Oct 6, 2011 | 02:05 PM
timmyboy76's Avatar
timmyboy76
Your right, rods. Thats not the sensor. I for got about that one. I meantthe one down on the pedestal. I have it unplugged, pedestal gutted..etc, what i'm asking, is if i can remove the sensor and plug the hole, but use the sensor elsewhere as a replacement, since that sensor is good? Or can i use it as a sensor for an another gauge?
Uglyhat
Jul 21, 2015 07:25 PM
JOHN2001
Aug 9, 2012 09:21 PM
Talyn
17
Jun 19, 2011 02:06 PM
pwrstk01
Feb 15, 2006 08:38 PM
