The bearing on my A/C idler pulley is making some noise when it's wet or cold outside. I figure it needs to be replaced. What are my options? Does anyone sell the idler & bearing assembly? Do I have to somehow remove and replace the bearing in the pulley? This is a dealer add on A/C set up. Here is a pic of the idler pulley.
That bearing is the same exact bearing as the front bearing in your alternator. (Unless you did the 3g of course). Buy an alternator bearing at your local parts house.
I notice your still running the oem vacuum advance on your dizzy. You may want to check that oldd sucker out & see if it's still good most these old oem one's are bad or slow vacuum leak.. Just a heads up.
orich
Watch getting the screws out of the housing. Usually just snap off. Might want to soak with PB blaster or such and give it a couple days. Work slowly and easily with screwdriver.
