Serpentine belt pulley bearing?
Looking to replace the bearings in my idler pulleys and tensioner during engine swap. Anyone know the bearing size offhand? If not I'll punch them out and measure. I know you can buy the entire assembly ($10-$30 ea.) but the bearing alone are very reasonable and I have a press.
Just get the number off the bearing and look it up.
The idea of replacing just the bearings is a good one, especially when you can find GOOD bearings from a manufacturer that you wouldn't normally find in an as-supplied pulley
I've used Gates and Dayco pulleys a few times on my modulars - the bearings usually start to whine within a year or two.
Next time, I'm just going to replace the bearings themselves with known-good parts.
madpogue
13
01-09-2016 10:24 AM
