A/C idler bearing
Old 02-24-2014, 10:21 AM
abyars111's Avatar
abyars111
abyars111 is offline
A/C idler bearing
The bearing on my A/C idler pulley is making some noise when it's wet or cold outside. I figure it needs to be replaced. What are my options? Does anyone sell the idler & bearing assembly? Do I have to somehow remove and replace the bearing in the pulley? This is a dealer add on A/C set up. Here is a pic of the idler pulley.
Old 02-24-2014, 01:18 PM
Freightrain's Avatar
Freightrain
Freightrain is offline
If you have a local bearing place(or a napa?), they will have the bearing. Nothing uncommon and I replaced mine years back.
With the belt off, unscrew the hex head and the pulley should come off the bracket. Knock the bearing out and replace it. Should be cheap.
Old 02-24-2014, 04:17 PM
kenny nunez's Avatar
kenny nunez
kenny nunez is offline
Thumbs up idler bearing
2x , a cakewalk
Old 02-24-2014, 04:33 PM
abyars111's Avatar
abyars111
Thanks. I'll take it off and disassemble.
Old 02-25-2014, 10:22 AM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
That bearing is the same exact bearing as the front bearing in your alternator. (Unless you did the 3g of course). Buy an alternator bearing at your local parts house.
Old 02-25-2014, 10:45 AM
abyars111's Avatar
abyars111
Thanks for the tip. I'll pick one up Friday.
Old 02-25-2014, 11:52 PM
orich's Avatar
orich
orich is offline
I notice your still running the oem vacuum advance on your dizzy. You may want to check that oldd sucker out & see if it's still good most these old oem one's are bad or slow vacuum leak.. Just a heads up.
orich
Old 02-26-2014, 07:48 AM
abyars111's Avatar
abyars111
Thanks, Orich. I've been wondering about that thing. I've considered just replacing it so that I know it's good.
Old 02-26-2014, 09:51 AM
Freightrain
Watch getting the screws out of the housing. Usually just snap off. Might want to soak with PB blaster or such and give it a couple days. Work slowly and easily with screwdriver.
villestrip
01-21-2017 01:59 PM
dcgayhart
Modular V10 (6.8l)
05-09-2016 09:42 AM
3wildboys
12-21-2011 08:05 PM
fatboy*61
08-14-2007 11:15 PM
beerdude41867
02-25-2007 01:49 PM
Quick Reply: A/C idler bearing
