Sponsored by: Real Truck
4R100E Transmission problems
Old Feb 24, 2014 | 07:39 AM
Joanne LaBelle's Avatar
Joanne LaBelle
My son's E350 Ford Van had a transmission problem. The van would shift if he manually placed it in first, 2nd, then over drive however when he put it in D it would not shift out of first gear. A transmission shop told him his trans was bad so he got a used transmission from a scrap yard and swapped it out. The newly installed transmission will not shift out of first gear and will not allow him to manually shift either. The OD light has been flashing since the first transmission. The transmissions are 4R100E's. Is it possible the first transmission was OK and what could the problem be???
rexblue
Apr 19, 2015 08:29 AM
fderflinger
Sep 13, 2007 11:49 AM
grind1
May 4, 2007 06:39 PM
Owl
Jul 21, 2006 01:42 PM
bettendorf
Feb 25, 2004 06:09 AM
