Intercooler setup?
Old Feb 24, 2014 | 02:55 AM
dieselkyle's Avatar
dieselkyle
Intercooler setup?
My question about the I/C setup is, is it worth the money to do this if i install a chip, intake and exhaust? I dont haul anything and i do mostly city driving and some highway driving on the weekends and its mostly flat roads.
Old Feb 24, 2014 | 07:38 AM
helifixer's Avatar
helifixer
no !
Old Feb 24, 2014 | 11:08 AM
dougbrown's Avatar
dougbrown
yes! lower egt, runs better imo!
Old Feb 24, 2014 | 11:23 AM
fordpride's Avatar
fordpride
If you don't tow then yiu don't need the IC
Old Feb 24, 2014 | 05:41 PM
dclack's Avatar
dclack
Like others have said, it's not worth it unless you tow or will be upgrading your injectors. I have intake, exhaust, and chip and I can't get up to 1200°F unless I'm towing. I do plan on getting stage 1's soon, so the intercooler is next on my list.
Old Feb 24, 2014 | 06:40 PM
dieselkyle's Avatar
dieselkyle
ah OK, ya I don't plan on getting stage 1`s for quite some time have to save up for them but I will plan on also saving up for an intercooler setup also, thanks for the info.
Old Feb 24, 2014 | 10:58 PM
pilgrimbizket's Avatar
pilgrimbizket
Take this for what its worth only reason I installed mine. The lower the egts are in the engine the more use you will get out of it. As in performance and durability
Old Feb 25, 2014 | 01:12 AM
strokin'_tatsch's Avatar
strokin'_tatsch
Don't bother with the IC until you upgrade injectors. The IC will lower EGTs and help make a little more power, but it is a good bit of work for minimal benefit. If you aren't towing or getting in any situations where EGTs become a problem, the IC is not worth the hassle IMO.
2002exPSD
18
Feb 24, 2011 10:30 PM
rattlerhill
Jun 25, 2009 11:09 AM
sumbuddyloanmea.10
Jun 10, 2009 09:10 PM
2 stroke man
Feb 21, 2008 05:31 PM
Yukon
20
Sep 25, 2004 09:34 AM
