Mods for dually?
Old Feb 24, 2011 | 06:54 PM
2002exPSD's Avatar
2002exPSD
Mods for dually?
Looking to mod my dually for fuel economy and a little more power.
What can I do? I'm thinking the big 3 first. Chip, exhaust, air intake. What else? Oh and I will be doing wvo soon. I don't tow more than 5,000 hardly ever.
Old Feb 24, 2011 | 07:45 PM
JamesHajek's Avatar
JamesHajek
First things first....Intake, exhaust and then GAUGES! Pyro at the very least... After that you can chip it. Then drive it. If you want more then it starts getting expensive.
Old Feb 24, 2011 | 07:53 PM
2002exPSD's Avatar
2002exPSD
Everybody has been on my azz since I modded my excursion cause I never had gauges. Don't see the need for them. 3 years so far and no problems.
Old Feb 24, 2011 | 08:01 PM
JamesHajek's Avatar
JamesHajek
Do what you want. You also have an intercooler on that Ex, you don't on the OBS. If it melts down the first time you run it with your chip and stock downpipe with a crap intake, don't say I didn't give you fair warning.
Old Feb 24, 2011 | 08:07 PM
2002exPSD's Avatar
2002exPSD
Well I was thinking ts chip, afe intake with ram air threw the grille,mbrp exhaust with dual 6 inch stacks.
Old Feb 24, 2011 | 08:42 PM
fordpride's Avatar
fordpride
do you plan on doing injectors
Old Feb 24, 2011 | 09:10 PM
2002exPSD's Avatar
2002exPSD
Nope. Not building another fast truck. Fuel economy for daily driver and towing cars to and from Louisiana. Maybe Having a little fun on the side laying down some black smoke.
Old Feb 24, 2011 | 09:14 PM
fordpride's Avatar
fordpride
That ^ plus gauges and that should be all you need
Old Feb 24, 2011 | 09:17 PM
2002exPSD's Avatar
2002exPSD
What gauges should I get? Egt, boost, and? Or do I only need egt?
Old Feb 24, 2011 | 09:22 PM
JamesHajek's Avatar
JamesHajek
At least get yourself a Pyro... If you want boost, you can get that as well.
fordpride's Avatar
fordpride
Boost,EGT, and Trans temp if auto
Old Feb 24, 2011 | 09:30 PM
2002exPSD's Avatar
2002exPSD
It's the one in the sig man. Zf manual. Will never buy an auto ever again. Ever!! Wish excursions came with manuals. =[ auto is going out in it.
Old Feb 24, 2011 | 09:32 PM
fordpride's Avatar
fordpride
Do atleast EGT Boost could help with MPG's the least amount of boost you make the better MPG's will be
Old Feb 24, 2011 | 09:43 PM
2002exPSD's Avatar
2002exPSD
You mean the most amount of boost makes better mpg? I deleted the waste gate on my excursion and got better mpg and more power. It's in full boost all the time.
Old Feb 24, 2011 | 09:49 PM
redman84's Avatar
redman84
I'd rather see temps or pressures than boost. EGT, Pyro, oil PSI, fuel PSI, etc... Boost is cool I guess but for mileage you don't need to see it. Mike is saying that try to make as little boost as possible when accelerating and you'll see a mileage increase. Well, there is only so slow you can accelerate. The biggest dynamic on economy is the skinny pedal. I drive pretty much like a grandma because I can barely afford fuel but I do still like to romp it some. There is no doubt after a tank when I had a little fun or not
