Does this Workas Make Sense?
Old Jun 24, 2009 | 09:56 PM
rattlerhill's Avatar
rattlerhill
Current situation on 2003 7.3L with primary use for towing:
1. Up-Pipe Leak
2. Ford Air Box
3. Small Exhaust
4. No Chip
From all I read, I can expect surging once I open exhaust, intake, and chip the truck. So I'm considering the following:
1. Put in Tymar Intake
2. Install 4in back exhaust
3. Replace up-pipes with IH bellowed setup
4. Remove Turbo and install wicked wheel
5. Install Chip
Anything wrong with this logic, am I over-analyzing the situation ... need suggestions on the order of work...I was thinking of just cutting out the exhaust and up-pipe assembly.
Thanks for any/all advice.
Old Jun 24, 2009 | 10:09 PM
nissandoc's Avatar
nissandoc
Cutting out? what exactly do you mean?
Old Jun 24, 2009 | 10:18 PM
Pocket's Avatar
Pocket
Make sure you put gauges on that list.
Other than that, looks good to me.
Old Jun 24, 2009 | 10:28 PM
Izzy351's Avatar
Izzy351
x2........
Old Jun 24, 2009 | 10:35 PM
PaysonPSD's Avatar
PaysonPSD
If you are going to remove the turbo you might as well replace the up-pipes. It's just a matter of how thin or thick your wallet is.
Old Jun 24, 2009 | 10:59 PM
rattlerhill
I should have worded it a bit clearer...should have said I intend to use a sawzall and cutout both exhaust and up pipes....replacing with 4" exhaust and IH bellowed up-pipe.
I only want to do this once and this will the extent of the performance mods...I'd like to do a mirror upgrade at some point.
Old Jun 24, 2009 | 11:10 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
I would cut your uppipes unless you have to because all those metal shavings will fall down into your manifolds, and then when you start up they will go through your turbo. Have you already found the Bellowed up-pipes, exhaust and gauges? Drop me a call, pm or e-mail and lets see what we can do for you.
Old Jun 24, 2009 | 11:22 PM
PaysonPSD's Avatar
PaysonPSD
Don't be surprised if once you unbolt the passenger side up-pipe at the exhaust manifold that it doesn't just twist out of the baby's butt. Those donut gaskets don't hold tight for chit.
Old Jun 25, 2009 | 02:16 AM
Stewart_H's Avatar
Stewart_H
Just call Clay (Riffraff) for everything on your list. He'll hook you up on everything you need.
Stewart
Old Jun 25, 2009 | 08:43 AM
milleroutdoors's Avatar
milleroutdoors
Definitely talk to Clay he can set you up in style. The uppipes will come out intact, just remove your stock exhaust first. If your careful you can sawzall your exhaust pipe but I agree with Clay i would not risk the metal in the manifold sawing the uppipes unless I had no other option.
Old Jun 25, 2009 | 10:51 AM
rattlerhill
Are you indicating I can unbolt the uppipes at the manifolds and when I pull the turbo, it will all come out intact up top?
Thanks for everyones advice, I've done an exhaust change on an old body style truck but I've never pulled a turbo or dealt with the up-pipes.
Old Jun 25, 2009 | 11:09 AM
PaysonPSD's Avatar
PaysonPSD
You have to remove the clamp that holds the uppies to the turbo, and remove turbo separately.
Edit: Pocket's Up-pipe Install Write-up LINK
