What's the easiest way to adapt a t5 to my 223?
I have had cast iron welded by specialists that are set up to weld WITH cast iron rod. You have to essentially weld in an oven at significant temperature and then cool the welded component down very slowly. It is difficult and therefore expensive.
People braze cast iron (basically hot glue!) but not where significant strength is required. Others will use a high nickel rod, better than braze but not as good as the cast iron rod method. I am going to venture out on a limb here and state that believe that the only widely accepted process to repair a cast iron component in significant tension is the cast iron rod method.
85bullnose250
05-18-2018 10:40 PM
cruisetopdown
05-12-2011 05:09 PM
Customcab
30
02-07-2007 09:28 AM
Pidgeon
01-04-2000 01:05 AM
