Boost? Questions
Old Feb 22, 2014 | 08:25 AM
PJ-Hunter's Avatar
PJ-Hunter
Boost? Questions
2003 F250 7.3l, stock except for 4" exhaust, intake and RiffRaff's billet compressor wheel.
Truck runs fines, but I noticed yesterday that it builds up boost faster when the motor is cooler. Just seems more snappy, you could say
After driving for a half hour or more it just spools up slower than when it's cool but still warm. Last night I had to run down and get some pizza after the truck had sat for a little over an hour and it spooled faster, up to 18psi. Motor was still warm from driving over 170 miles. While driving that 170 miles it was doing something what I would call lag, would only boost up to 11-12 when passing someone.
ideas?
Old Feb 22, 2014 | 08:39 AM
CampSpringsJohn's Avatar
CampSpringsJohn
The first things that come to mind for me are boost or exhaust leaks. But those should show their ugly head all the time.
Then, I'd ask how old is the oil?
What type of oil are you running?
How many miles on the truck?
How does your truck start when it's all warmed up?
Old Feb 22, 2014 | 10:18 AM
takotruckin's Avatar
takotruckin
How long ago did you do the compressor wheel? Was there any play in the turbo shaft? High temps could cause more drag in the turbo bearings if there is a problem there. But you could also have a high pressure oil problem starving the engine of fuel.
Old Feb 22, 2014 | 12:33 PM
PJ-Hunter's Avatar
PJ-Hunter
Oil has 1000 miles on it
Running Rotella T 15-40
Truck has 150k
When warm, starts fast.
July is when I did the wheel. No play on the shaft. Rebuilt the turbo in July when I did the wheel
Old Feb 22, 2014 | 02:17 PM
BadDogKuzz's Avatar
BadDogKuzz
It could be all of the above but I would start by checking for up pipes leaking and boost leak tester.
Old Feb 22, 2014 | 03:17 PM
PJ-Hunter's Avatar
PJ-Hunter
Is there a DIY boost leak tester available that won't cost me a fortune?
Old Feb 22, 2014 | 03:52 PM
JOHN2001's Avatar
JOHN2001
Do a search there's a thousand of them
Old Feb 22, 2014 | 03:54 PM
1996pwrstrk's Avatar
1996pwrstrk
Here's one cookie88 made up.
Old Feb 22, 2014 | 05:55 PM
snknby123's Avatar
snknby123
I would have to agree as it sounds like something is heating up and expanding causing a boost leak. Get your boost leak checker and check the boots at the intakes under the spider and inter-coolers. Also consider something could be causing the waste-gate to open more after it warms up?
In case its something more complex you need to monitor your sensors. You didn't mention you have anything so I will recommend the cheapest alternative.
https://www.ford-trucks.com/forums/1...-in-bacon.html
This will enable you to gather data when cold compared to operating temp if something funky is going on with your HPOP/injectors etc.....
Old Feb 22, 2014 | 08:50 PM
HD Rider's Avatar
HD Rider
Check fuel pressure while driving.
Old Feb 23, 2014 | 06:14 AM
Tugly's Avatar
Tugly
Sorry, my good friend... this needs revising. I had an intermittent boost leak... not easy to find. My intake plenum seal was weak, so it would be good at times, then give way.
There's a commercial product available?
Old Feb 23, 2014 | 08:23 AM
CampSpringsJohn
OK, so some boost leaks are intermittent. I guess some exhaust leaks could be the same. Checking for leaks should be the first thing to do for sure. I was also thinking that possibly the ICP was dropping when warm from the o-rings failing. That is a common problem when they get some miles on them.
Old Feb 23, 2014 | 11:14 AM
HD Rider's Avatar
HD Rider
For stock turbos.
http://www.dieselsite.com/dieselsite...ector-4-1.aspx
For ported housings.
http://www.dieselsite.com/dieselsite...etector-4.aspx
biggdirty7.3
19
Jun 8, 2017 05:01 PM
Anthony Giovino
Ford Truck Parts for Sale
Apr 15, 2017 07:50 AM
Ryan313
Jun 18, 2016 11:04 PM
davidson915
17
Jan 24, 2008 05:41 PM
Barnknee
Apr 1, 2003 02:31 PM
