56 Gas Tank Fitting size and modifications:
Old Feb 19, 2014 | 08:29 PM
clintonvillian's Avatar
clintonvillian
Fellas, what size and type is the female outlet on the pick up tube of the tank. The place that the hard line threads into?
I need to place a return line and vent, can I just weld some AN fittings in the top of the tank?
Old Feb 20, 2014 | 01:44 AM
Normalbloke's Avatar
Normalbloke
It is a 1/2" SAE 20 TPI with a 37 degree seat. I asked this very question about 3 months ago and didn't get the answer.
I opted to weld a -8 fitting at the bottom of the tank to use as a pickup, and am using the top original pickup as my fuel return with a screw in -6 adapter.
Good luck.
Old Feb 20, 2014 | 06:55 AM
clintonvillian
Any issues with sediment using the sump line in the bottom, that was one of my concerns?
I was considering using the tank drain and seeing if I could get a nipple to thread in there with an 8 AN fitting on it.
What did you do for a vent?
Old Feb 20, 2014 | 07:39 AM
Normalbloke
Hi, I haven't used the original sediment/drain bung, that's still there. I have a new steel -AN8 bung welded onto the tank just above the bottom, on the driver's side of the tank. It collects from about the same height as the original tube pickup. I'm having a seperate 3 litre tank , that the fuel injection pump will feed from to avoid fuel starvation. I also believe that the original fuel pickup tube isn't big enough to support high bhp/fuel injection stuff.
Old Feb 20, 2014 | 07:54 AM
clintonvillian
Tell me a little more about the second tank. What causes starvation and the need for it?
Old Feb 20, 2014 | 08:12 AM
Normalbloke
Not a huge amount to tell! Starvation can be caused by many things, my concern is the shape of the tank and where the pickup is. 1/3 of a tank or less and an extended corner or roundabout could easily see the pickup tube sucking air.
So, I have a different pickup point that is larger, and a facet red top pump pulling fuel via a filter, into a taller thinner 3 litre tank, with an overflow back to the tank. This will effectively always be full. At the bottom of this second tank, is the feed out for the fuel injection pump prefilter then onto the pump itself.
It should work, as I ran this system on a turbo charged Caterham I had, which would have incurred damage due to fuel starvation if on boost.
Old Feb 20, 2014 | 08:27 AM
clintonvillian
I am glad you brought this up. I live in a curvy mountainous area so this may be a concern for me on my S/C engine.
Any pics of your setup?
clintonvillian
Are you running 2 fuel pumps then?
Old Feb 20, 2014 | 09:10 AM
Normalbloke
Yes. A high volume low pressure carb jobby to keep the small tank fed. Then the fuel injection pump will feed from that.
Over your side of the pond, Id imagine it would be easier to source an under bed tank with an internal anti surge pot and internal pump?
Old Feb 20, 2014 | 09:13 AM
clintonvillian
I don't have room for an underbed tank. Most of the aftermarket tanks I am coming across have nothing to prevent it either.
Old Feb 20, 2014 | 09:14 AM
Normalbloke
No pics of the setup yet I'm afraid, it's still a pile of parts. I have only just got the main tank back from powdercoat. I have most of the fittings and pumps, just about to do some final measuring up for the smaller tank.
JackLewis
Jun 21, 2018 07:52 PM
hurst1979olds
Dec 3, 2016 06:08 PM
Holehawgg
Mar 20, 2014 09:21 PM
56Overdrive
Mar 8, 2012 10:53 PM
tcbofade
Jun 9, 2006 06:51 PM
