Galvanic Corrosion
Old Feb 19, 2014 | 09:31 AM
dirttydawg's Avatar
dirttydawg
Galvanic Corrosion
'galvanic corrosion' developing where the aluminum cab & bed attach to the steel frame could be a real concern.
https://en.wikipedia.org/wiki/Galvanic_corrosion
This could be a serious problem especially for those driving in the snow (salt) belt.
Hopefully Ford has done due diligence.
Old Feb 19, 2014 | 11:19 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Welcome to FTE!
I'm pretty certain that Ford has taken this into consideration and will likely insulate the metals from each other.
Old Feb 19, 2014 | 11:39 AM
dirttydawg's Avatar
dirttydawg
Originally Posted by tseekins
Welcome to FTE!
I too have faith that Ford has addressed this potential issue.
It is a complicated problem. Let's say you place a nice thick piece of plastic with a bolt hole in it between the aluminum bed and the steel frame. Now, most likely, you use a steel bolt and nut to secure the the two. You would have to insulate the area of the bed where the bolt head contacts the bed and insulate the bolt hole in the bed. As I said, complicated.
Old Feb 19, 2014 | 12:07 PM
cv67cheng's Avatar
cv67cheng
Use dielectric strips between the dissimilar metals and sleeve the fasteners, just like we do on ships.
Old Feb 20, 2014 | 03:37 PM
dirttydawg's Avatar
dirttydawg
Sounds like a plan. Hopefully Ford has the same plan
Old Feb 20, 2014 | 03:44 PM
paredneck33's Avatar
paredneck33
Here maybe this video will help relax you a bit. Not quite sure what there full plan to battle this issue is though. However the cab will be fine as it is cushioned by rubber mounts that separate it from the frame.
Old Feb 20, 2014 | 07:29 PM
efx4's Avatar
efx4
Working in autobody for 27 years, I've been seeing increasing use of aluminum in most vehicles. Galvanic reaction is something that has been dealt with for years with various types of barriers, such as thread coatings for bolts (like with aluminum hoods and steel bolts), gasket and plastic washers, as well as paint materials. The problem isn't in the manufacturing process, it's at the repair shop level, where some ill trained technicians don't repair the vehicles properly.
Old Feb 20, 2014 | 08:41 PM
paredneck33
I totally agree with this statement.
Old Feb 21, 2014 | 09:20 PM
GuyGene's Avatar
GuyGene
Unhappy
And I agree with pared.
Old Feb 21, 2014 | 10:01 PM
paredneck33
So I was talking to a Ford sales rep last weekend at the Pittsburgh auto show. He said that Ford is claiming that this aluminum body will last at least 3 times longer then the current steel bodied trucks we are use to.
Old Feb 27, 2014 | 06:08 PM
super 6.8's Avatar
super 6.8
Stainless hardware goes a LONG ways to prevent corrosion.
Old Mar 1, 2014 | 09:20 AM
92f150I6's Avatar
92f150I6
Believe it or not, stainless bolts can still gall in aluminum.
Old Mar 1, 2014 | 01:02 PM
GuyGene's Avatar
GuyGene
If even I, as a total metallurgical ignoramus, know enough to not let aluminum contact steel for use in a truck - hey, this is not an issue. Move on, nothing to see here. I'll meet y'all in the food court.
Old Mar 1, 2014 | 01:38 PM
seventyseven250's Avatar
seventyseven250
This sounds about right to me. I think repairs will need to be pretty meticulous, but to be honest, repairs are getting more and more specialized anyway.
Can't wait to see and drive one of these.
Steves55
15
Feb 22, 2017 09:44 PM
wolfgang031691
1997 - 2003 F150
Jan 21, 2011 06:40 AM
77_150
Jan 7, 2011 02:31 PM
Behemoth
13
Aug 24, 2008 11:55 PM
Bill79Lariat
Jan 1, 2004 05:30 PM
