Bed Pads-Do I really need them?
Old Feb 21, 2017 | 01:09 PM
Steves55's Avatar
Steves55
I am in the process of refinishing the bed wood and noticed that most of the rubber pads that sit between the cross sills and frame were missing. Since it looks like I will be spending more for shipping than the price of the replacement set of 6, do I really need these? Thanks. Steve
Old Feb 21, 2017 | 01:32 PM
abe's Avatar
abe
Not sure. I don't think you really have to have them but Ford must have put them there for a reason, squeeking, metal on metal wear, rust issues between frame and bed perhaps?
If you can obtain good thick rubber stock you can it your own and punch a hole in it for the bolt.
Old Feb 21, 2017 | 03:11 PM
schoo's Avatar
schoo
remember that the bed needs to line up with the running boards and some space at the frame is occupied by mount rubber do 55 RB bolt to the fenders
Old Feb 21, 2017 | 03:40 PM
drptop70ss's Avatar
drptop70ss
I made my own cut out of rubber sheet that I think was cut from an old conveyor belt. Amazing what can be found at the swap meets for a few dollars. I would not leave them out myself.
Old Feb 21, 2017 | 03:51 PM
raytasch's Avatar
raytasch
Believe Nothing
Flat belts like they used to drive old machinery with will work just fine. Yeah, as said, put something in there.
Old Feb 21, 2017 | 03:56 PM
schoo's Avatar
schoo
mud flaps work also
Old Feb 22, 2017 | 03:47 AM
petemcl's Avatar
petemcl
For squeaks and rattles particularly when the bed had no load. Both the belt and the mud flaps are good ideas . . . maybe an improvement over the original.
I used Trex blocks but I needed to build up the mounting area as I am using an F1 box on a shortened F1 frame.
Old Feb 22, 2017 | 09:29 AM
CharlieLed's Avatar
CharlieLed
I have used 3M squeegees, the black rubber blocks used by body shops to spread body filler.
Old Feb 22, 2017 | 11:06 AM
pweng1's Avatar
pweng1
Home depot and lowes sell rubber that can be used.
Old Feb 22, 2017 | 11:24 AM
burnettd01's Avatar
burnettd01
Bed pads
The rubber that Home Depot and Lowe's sells - what is the use that it is sold for. In other words, what is its intended use - just so we can look for it in the store and find it easily.
Don't need it for the bed yet, but I have a couple of other places on my truck that I could use it for.
Thanks
Dan
Old Feb 22, 2017 | 11:48 AM
pweng1's Avatar
pweng1
Thanks
Dan
They are used for vibration dampers>. I used the first one for a motor mount custom insulation and the other you can cut in smaller squares. I found them handy when you need something right away
Powermate 2.25 in. x 1 in. Vibration Isolator-094-0190RP - The Home Depot
Powermate 4 in. x 4 in. x 1/2 in. Vibration Isolator-094-0137RP - The Home Depot
Old Feb 22, 2017 | 12:17 PM
schoo's Avatar
schoo
dan I have a mud flap its I think both 1/4" and 1/8"
Old Feb 22, 2017 | 12:52 PM
burnettd01's Avatar
burnettd01
Rubber isolators
Thanks pweng1 - just what I was looking for!!!
Roy, mud flaps will work Great too! Hard to cut but should be able to drill a hole easily enough - maybe cheaper as well.
Thanks
Dan
Old Feb 22, 2017 | 03:23 PM
schoo's Avatar
schoo
Thanks
Dan
hard to beat free and I cut with tin snips
Old Feb 22, 2017 | 06:17 PM
Steves55's Avatar
Steves55
Thanks guys. I will fab some up. Steve
