Sponsored by: Auxito
Bed Loose - need help
Old Jan 20, 2011 | 07:53 AM
wolfgang031691's Avatar
wolfgang031691
Friend of mine has an '02 F150 Lariat, quad cab, short bed. I've seen his problem dozens of times on Fords but never had to fix one.
His passenger side front bolt on his bed floor is loose (likely a deteriorated rubber grommet). Now he can lift the bed by hand about 2-3 inches. Every bump he goes over, the bed bounces and bangs against the frame.
When I look under it, there doesn't seem to be a practical spot to access the bolt through the frame. We can pull the tie-downs and bed liner and get to the carriage bolt that way but I'm not sure how that would help us b/c I still need to get on the nut.
Can anyone help me on this?
Also, am I right about the grommet/spacer deteriorating?
Old Jan 20, 2011 | 07:06 PM
moto57's Avatar
moto57
The bed bolt is a TORX head, Most beds I have pulled have rubber pads glued to the top of the frame. That TORX head bolt threads into a frame clip nut accessible from the top usually.
Rubber pad may have come off, The frame clip nut may have loosened or rusted.
Ace Hardware has a great selection of replacement items for that rubber pad if that is the issue(rubber, nylon, etc)
Maybe that bed has been off previously, and wasn't reinstalled correctly.
Dozens? Personally Have never had a problem with a Ford Truck Bed!
Old Jan 21, 2011 | 06:40 AM
wolfgang031691
Great info. Thanks!
Dozens? Yes. All have been Rangers though until now. This is the first F150 have seen like this.
superman64011
32
Feb 13, 2022 10:33 PM
Ford59galaxie
Dec 15, 2015 05:08 AM
greg in the oc
15
Mar 27, 2012 10:58 PM
tex-can
15
Feb 25, 2005 06:45 PM
