fuel pump again?
Go out tonight same problem. Same routine only this time gas does not keep flowing. Disconnect rubber hose no gas, blow on fuel fill inlet gas flows good for a few seconds then stops. Blow on inlet again gas flows good for a few seconds and quits again. Seems like the gas should keep flowing? Does it need suction from fuel pump to keep flow? Not far from home so I fill bowl till it quits. Get out fill bowl again till I get home.
This is my third pump in just over a year. Between last 2 pump replacements I cleaned out lines, gas tank twice, replaced all rubber hoses and filter. Every time problem got this bad replaced fuel pump and problem solve till pump / problem comes back.
Tomorrow I'am going to hook up a gas can before the pump and see if truck will keep running. Any thoughts as to what is going on? Thanks.
Maybe it's time to install a back up electric pump like a few of us has done.
These little pumps are a flow through so it don't effect the manual pump pull of gas. These will help push gas to your manual one.. I'm some day going to ad another tank so I have a tank switching valve inline with mine..
orich
http://i103.photobucket.com/albums/m...ithshutoff.jpg
On a lighter note, I had a 68 f-250 4x4 back in the day that I bought super cheap because it would run perfect for a week or so then die stone dead. He had it to several shops and nobody could figure it out.
I had it for a month before it happened the first time, and I did the same routine as you out on the hyway and got it home, when I opened the tank, turned out, somebody had used clear silicone to seal the sending unit oring at some point, they used too much and a snake about 4" long got severed when he installed it and it was floating in the tank, the pickup tube didn't have a screen so the snake would float around for awhile until it found the pickup tube and get stuck there, if you left it alone long enough to tow it to a shop it would slide back out
. easiest fix I ever had.
I find it strange that gas won't keep flowing from tube coming off sending unit. If I disconnect the rubber hose from metal line blow into gas tank it flows good but only for a few seconds. I know tube goes to the bottom of the tank but the other is lower than the tank? I'am going to check that metal line as best I can and try to run something thur it to clean it out. I think maybe that's where the problem is or the pump has gotten weak and does not have enough suction to keep gas flowing. (Cheap donkey after market crap) Maybe an air leak somewhere from tank to rubber hose connection? (rubber connection hose was replaced in past year)
Please tell me more about electric pump back up. Is this a replacement for mechanical pump. Please tell me about your set up's, brand if you use a fuel reg. etc. If I go that route I would prefer to get one from a brick and mortar store as I need to get this thing up and running again.
Going out to do some checks in a few, will report back my finds. Thanks for the suggestions!
Looking at these.
http://shop.advanceautoparts.com/web...p2HomeClicked=
Or keep mechanical and add this.
http://www.autozone.com/autozone/acc...fier=732036_0_
Have you hand tested the pump after removing it?, By working the pump arm lever that ride on the offset wheel that is bolted onto the timing gear to see if is still working?
This wheel wears down just enough to not work the pump over yrs of use.
This sounds like what's going on since you have gone through so many in the last few yrs.
Their is a repair kit when this wheel wear down to much..
orich
orich
Checked out lines by blowing on them but have not blown compressed air thur them yet. All lines seem clog free tank to carb. Really think pump is bad/weak.
I'am going to hook up pumps to tank and work pump by hand to see if I get any draw.
All tubes look good the only one I can't visually check is the inside draw tube. Blow on it and I can hear gas bubbling so I assume no holes/leaks.
Just did vacuum test on both pumps and getting about 7 to 8 psi.
