warn lock out hub issue
Old Feb 18, 2014 | 05:12 PM
JOHN2001's Avatar
JOHN2001
A week ago my 4wd stopped working. I've diagnosed it to be the hubs. I took them apart regressed everything and put it all back together. Everything looked to be in good shape for the most part, I noticed the snap ring came off the back of one so I put it all back together and called it good because it seems to be functioning like it should.
The opposite side doesn't seem to want to spin to lock by itself even after being greased. If I just twist the switch enough it doesn't move where as the other side will free spin all the way to lock.
Theres really not much to this design it's about as simple as it gets. Am I missing something? Any help would be great. I did try to look up maintenance on warn hubs and haven't seen anyone with a problem quite like mine. Unfortunately for me I don't have the receipt of the hubs when I bought them 3 years ago and I don't want to have to fork over $200 if I don't have to. Thanks
Old Feb 18, 2014 | 05:45 PM
Firefighter 1406's Avatar
Firefighter 1406
If you haven't already I would call Warn customer service. I have heard they are very helpful and have heard of they replacing stuff no problem.
Old Feb 18, 2014 | 06:59 PM
SARDiverDan's Avatar
SARDiverDan
I have always wondered about that snap ring as there is no grove for the ring to snap into so I have never used them and have not had an issue.
Old Feb 18, 2014 | 08:02 PM
scotttahoe's Avatar
scotttahoe
I agree, call customer service.
Old Feb 18, 2014 | 08:07 PM
rotun's Avatar
rotun
Reads ***** rules!
You might have put too much grease in them.......it doesn't need alot, too much will prevent it from functioning correctly.
Old Feb 19, 2014 | 05:12 AM
JOHN2001's Avatar
JOHN2001
I'll be contacting there customer service today thanks for the tip. Rotun I didn't over do it. To me it looked like there was enough grease already. I wiped them out and applied a little more I figured it couldn't hurt since they weren't working anyways.
Old Feb 19, 2014 | 10:36 AM
rotun's Avatar
rotun
Reads ***** rules!
If you ever decide to stray from Warn the Dynalocs from Dynatrac have been very good. Pricey but you'll only pay for them once.
Dynatrac - Confidence to Explore®
Old Feb 19, 2014 | 11:07 AM
HKusp's Avatar
HKusp
Superwinch hubs are the way to go on these trucks. That weak *** spring that Warn puts on doesn't do the trick after awhile. Superwinch's has no spring it is a mechanical wedge. Positive lock every time. I had Warn premiums and they were junk. I got warn to replace them under warranty and sold them to purchase the Superwinch set, which was cheaper than Warn by the way.
Model 400439 fits the Dana 60's
http://www.superwinch.com/p/premium-...ler-ford?pp=12
ss27gogeta
May 31, 2019 06:02 PM
mad_science
Jan 29, 2018 09:57 AM
wallz
Jan 19, 2011 11:01 PM
phf2231
Apr 25, 2010 06:37 AM
CruisnPhantom
Mar 7, 2004 09:38 PM
