Vibration vs codes
Old Feb 16, 2014 | 03:38 PM
Talyn's Avatar
Talyn
Vibration vs codes
Trucks' sat for a few months.
decided to start it.
I had an epiphany on the thinking throne this morning.
CPS.
I think I might have switched from the Grey to the purple while i waited to replace my axle.
Always possible.
Pulled codes.
I have a 0562 (not listed)
and a 0236.
The other code i have is a turbo circuit code, that one pops up randomly. (0344)
so, a 05 code is an idle code.
And a 236 is a CMP code.
What ya'll think are the chances that purple IH sensor is causing my issue?
I'd swap them, but I have to go get a replacement O-ring for the grey CPS.
I wish I still had my black one. =*****(
It died.
Old Feb 16, 2014 | 04:14 PM
ReBilld's Avatar
ReBilld
CPS.
Always possible.
Pulled codes.
and a 0236.
It died.
What is the issue?
Old Feb 16, 2014 | 04:16 PM
Talyn's Avatar
Talyn
Originally Posted by ReBilld
What is the issue?
The same one i've had since last year.
You read the title right? =)
Old Feb 16, 2014 | 04:19 PM
ReBilld's Avatar
ReBilld
The vibration?
Old Feb 16, 2014 | 04:20 PM
Talyn's Avatar
Talyn
The vibration?
uhm...
yeah. =)
Old Feb 16, 2014 | 04:23 PM
ReBilld's Avatar
ReBilld
I thought that was something in your drive line.
Old Feb 16, 2014 | 04:26 PM
Talyn's Avatar
Talyn
The point of the thread was to get opinions on if my vibration could be my CMP not a driveline issue.
AKA.
Could a CMP cause vibrations in the motor?
Old Feb 16, 2014 | 04:37 PM
ReBilld's Avatar
ReBilld
I suppose it could. you should be able to tell if the vibration is engine specific or drive line specific by accelerating under load or coasting down a hill.
Old Feb 16, 2014 | 05:59 PM
Talyn's Avatar
Talyn
Well, nothing is "normal" about how it works.
So.
Old Feb 16, 2014 | 10:06 PM
dougbrown's Avatar
dougbrown
CMP?????
I would also think it would be easy to tell if it engine or drive line with a ZF5. When your driving down the road and clutch in does it go away? If it does then I'd say it driveline. That normal how we do it with the Mack's at work. I could be wrong though.
f1501987
13
Mar 30, 2012 05:58 AM
mikeyc0120
Aug 15, 2010 05:45 PM
4inchlovin
13
Jan 21, 2009 07:14 PM
808 7.3
May 29, 2008 05:59 AM
99f250
Jul 25, 2003 12:47 AM
