Code P0284 Cyl 8 Contribution/Balance?
Old Aug 14, 2010 | 10:19 AM
mikeyc0120's Avatar
mikeyc0120
Can someone explain what the above code is and how to figure it out? I had an ICP issue and replaced it. Seemed to work fine for a 19 hr/1200 mile drive to NY and the last 20 min of the trip started the same symptoms as the original ICP issue. I was able to get a hold of an old Snap on reader and were able to pull codes and run some tests. One of which was the P0284. So if anyone can let me know what to check that would be great! Thanks!
Old Aug 14, 2010 | 12:24 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Ignore the 0284 code for now and focus on the other ones. Can you list all the codes you found? What symptoms are you having?
Depending on what CPS you have (including the one that Ford installs for their recall), the 0284 can be a phantom code so I wouldn't give that one too much weight right now.
Old Aug 14, 2010 | 01:38 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
If you have the grey CPS I would swap it out for an original black one and try it again.
Old Aug 14, 2010 | 06:18 PM
mikeyc0120's Avatar
mikeyc0120
Riff - I actually don't know which one I have.
The only other codes were ones for the torque converter clutch which is from the ebpv brake mod, a P1876 for a transfer case solenoid (which I have no idea that problem) and the P1280 for low ICP reading. But that was in memory codes and was present before swapping the ICP. I wasn't able to reset the codes after the swap so not sure if thats a code prior to or after swapping.
Old Aug 15, 2010 | 05:45 PM
mikeyc0120's Avatar
mikeyc0120
Clay, I havent done any cps swap so Im not sure whats in it. Where is it and how can I tell?
bowranger
Mar 26, 2016 09:54 AM
skylinetowing
Sep 16, 2012 07:10 AM
jeremy53402
Jun 29, 2008 05:46 AM
jeremy53402
Jun 28, 2008 08:03 AM
808 7.3
May 29, 2008 05:59 AM
