Rear Diff Help
Old Feb 16, 2014 | 04:50 PM
snakedoc's Avatar
snakedoc
i have not pulled the pinion out ran out of time. hope to get it in the morning
i have seen no metal nor do i fill any drag on the pinion, all i have found is a small amount of play and the marks on the carrier.
Old Feb 16, 2014 | 06:11 PM
Lying Larry's Avatar
Lying Larry
I found all my shim material waded up and in the passage that goes forward to lube the front pinion bearings. Mine had never been touched after leaving the factory either. I wondered if it may have been over torqued and crushed the crush washer too much then backed off and re tightened leaving the crush washer crushed too much.
Old Feb 16, 2014 | 07:59 PM
snakedoc's Avatar
snakedoc
i will find out and see what i need to order.
Old Feb 17, 2014 | 12:03 PM
snakedoc's Avatar
snakedoc
the bearings look good the shaft it in good shape less then .001 out.
the crush sleeve is very loss on the shaft and it has worn the ID on 1 end to where it will float. the races look like the wear has just started as they have no show of loading and uneven wear.
the pinion has 3 teeth that have a mark on them where they scrubbed the housing and 1 that has a small chip on the very end where the gear dose not run so dont see there being any problem to use the gears. ii going to clean them up and set it back and see what happens.
all i can say is change you rear oil and check the diff as mine has never made a sounds or leaked, but was not far from a big failure .
Old Mar 3, 2014 | 02:49 PM
snakedoc's Avatar
snakedoc
get it her running Saturday and drive it 50 miles this weekend, so far there is not noise no leaks and there is only normal temps on the diff. only time will tell but it looks like it is good to go. thanks for the help.
IDIDieselJohn
May 1, 2018 11:22 PM
wwgk1980
Jun 26, 2014 01:30 PM
XtraHam
Jan 16, 2010 12:22 PM
emptyd
Sep 19, 2007 05:00 PM
therigwelder
May 27, 2005 07:24 AM
