Sponsored by: Real Truck
Loose pinion
Old Jan 16, 2010 | 11:20 AM
XtraHam's Avatar
XtraHam
Loose pinion
good day folks, I have a 1997 (OB) F250 H/D 4x4 xcab powerstroke with A LOT of miles
I was checking out my truck to get ready to go on a road trip and I found a loose rear pinion, it was seeping a little oil but not bad for as loose as the pinion was.
I pulled the rear U-joint and it didn't look as if the pinion nut had backed off but it was real loose. I had noticed that the rear had started singing a little on acceleration and at highway speeds and clunking at stop and go.
I tightened the pinion nut and it went up about 1/4" before I was able to get any preload, it's still singing but not as bad.
What do you think I need?
Bearings, seal, and new crush sleeve? or is the rear shot?
thanks
Old Jan 16, 2010 | 11:45 AM
AlaskaJeff's Avatar
AlaskaJeff
It almost sounds like the pinion bearing is bad. I would say pull the diff cover off and take a look at the R&P to see if there is any noticable wear patterns. You MAY be able to get away with a new pinion bearing, crush sleeve, and seal and it will be good. IF ther has not been any adverse wear on the R&P.?? I'm no mechanic but I can tear ANYTHING down and sometimes get it back together and working!!
Old Jan 16, 2010 | 12:22 PM
bill64's Avatar
bill64
i also agree, i would look at the ring and pinnion for wear due to the loose pinion, at this point especially with high mileage probably due for an overhaul, you will have to disassemble it for pinion bearings anyhow.
a couple ways to loose pinion preload is bearing wear, and spinning the tires on ice or sand then the tires hook solidly can push the pinion into the ring gear, at the same time crushing the crush sleeve just enough to loose preload.
DSN46
Dec 7, 2013 06:18 PM
bbf150
May 22, 2013 08:45 PM
redman84
Feb 5, 2012 10:15 PM
cidme
1983 - 2012 Ranger & B-Series
Nov 13, 2008 07:59 PM
tcart38
New Member Introductions
May 10, 2008 02:29 PM
