Rear Diff Help
Old Feb 14, 2014 | 03:36 PM
snakedoc's Avatar
snakedoc
Rear Diff Help
I was going to put a Detroit turetrac in the 10.5 rear end. my camera is not here right know so i will post pics later. the diff dose not make any noise. when i pulled the Carrier it has marks on it like the pinion gear is rubbing it. i can mover the pinion gear around 1/64" in any direction, i think my pinion bearings are going out. i have never done a diff before but i have head and am good at wrench turning. the gears have no chips are marks on them so there good to use again, i just cant see how the pinion moves that much and not making noise? the bearing kit for the pinion is $200 that is more than i paid for the turetrac. im i over looking something or is it need a rebuild?
Old Feb 14, 2014 | 04:31 PM
clux's Avatar
clux
Is it possible that somebody did a shade tree pinion seal replacement and the pinion nut has backed off?
Old Feb 14, 2014 | 05:00 PM
snakedoc's Avatar
snakedoc
what is the best way to check?
there is no metal in the oil no brunt smell just a perfect pattern where the gear rubbed.
do i need to pull the pinion and check the bearings or just snug it to spec. i have had the truck for 45k miles so i dont know what it might have ruined?
Old Feb 14, 2014 | 05:07 PM
clux's Avatar
clux
No, that's the problem, people re-use the pinion nut and they are a one use part, that's why they back off.
If it was mine I'd pull the pinion to see what's going on if you're comfortable doing that, and at the very least you'll need a new pinion nut and crush sleeve.
Old Feb 14, 2014 | 06:01 PM
snakedoc's Avatar
snakedoc
i can pull the pinion and check.
have you seen the crush sleeve eliminator?
here is a clip
I am positive the Ford 9in crush sleeve eliminator works with a 10.25 and 10.5 axles. I put one in my old bronco when I swapped in a 10.25 with a Detroit and 5:13's.
"The pros far out weigh the cons in my opinion. You can swap yokes with no worries but the biggest one is you don't have to worry about the crush sleeve "crushing more" over thousands of miles and torque and then as a result destroying your pinion bearings. The only con is setup time. to properly do the solid spacer you have to assemble it all and check everything then tear it apart and do it again if the preload isn't right. I made myself setup bearings so its easier but still kinda a pain."
what do you think is it worth the trouble of setting it up?
also it looks like i need new ring gear bolts as i have seen where you are not to reuse them? is this right as the ford shop manual dose not say to get new ones?
Old Feb 14, 2014 | 06:04 PM
Lying Larry's Avatar
Lying Larry
On my truck at about 140 000 miles I had the shims behind the bearing and pinion brake up and come out. That looses any pre load and my truck sounded like a u joint was starting to fail. My pinion bearing was a slip fit so the tooth contact was wrong with out this .020 shim.. I bought the truck new and it had never been touched. I built a new .020 shim and used cat retaining compound on the bearing and shim and reassembled. A new crush sleve and nut and went back together. About 50 000 miles ago. Not by the book but not 1900$ repair either. More like 15$
Old Feb 14, 2014 | 08:58 PM
snakedoc's Avatar
snakedoc
the marks are light not deep and the gears look good, the wear on the spider gear is to far in where the pinion is floating
Old Feb 14, 2014 | 11:21 PM
timmyboy76's Avatar
timmyboy76
yo snake, got me an extra axle from back in october. i got the eliminator kit waiting to be installed in it. atter of fact, its installed, just not "set" yet. When i find someone who knows how to set it, this rearend will be going back into truck..(04 axle)
Old Feb 15, 2014 | 08:55 AM
snakedoc's Avatar
snakedoc
i have never done one but it dose not look to bad just take your time setting the preload.
i will have to order the parts so i will have to wait on them.
Old Feb 15, 2014 | 10:23 AM
timmyboy76's Avatar
timmyboy76
ya...with 250lbs to set the eliminator, vs 650lb to set sleeve...i'll do the shim route.
Old Feb 15, 2014 | 11:46 PM
snakedoc's Avatar
snakedoc
where did you find the 250lbs spec?
another site said 150lbs?
it is not in the manual so i trying to get a good handle on it before i start.
Old Feb 16, 2014 | 09:19 AM
timmyboy76's Avatar
timmyboy76
Sterling 10.5" differences - PowerStrokeNation : Ford Powerstroke Diesel Forum...
not sure where i got the 250#, but found this....1st post
Ratech crush sleeve eliminator
Old Feb 16, 2014 | 10:04 AM
takotruckin's Avatar
takotruckin
EEK. The solid pinion spacer is an OK idea. I don't have on on my truck, but many wheelers run them for ease of maintenance. The problem with the pinion nut isn't backing off, its that people either under or over tighten it when replacing the seal.
Depending on how long it has been like that, I would plan on the gears making a little noise after the are set up properly again.
Old Feb 16, 2014 | 12:40 PM
snakedoc's Avatar
snakedoc
i got the truck from the original owner and he has never had the diff touched.
so this has happened over 192k miles from the factory set up.
it dose not make noise now but so i hope it dose not when fixed, as the gears look good.
im going to set it back up and see what happens.
Old Feb 16, 2014 | 04:40 PM
takotruckin
Have you gotten it apart yet? I would expect to see a broken shim or worn bearings.
