1966 - 1977 Early Broncos
C6 in an E.B.
Old Feb 20, 2014 | 07:31 PM
  #61
UNTAMND's Avatar
UNTAMND
Originally Posted by david00f150
What's the advantage to a twin stick?
Why did you ask if it was only a twin stick?
The advantage of it would be the low range 2wd feature.
Old Feb 20, 2014 | 08:48 PM
  #62
Nothing Special's Avatar
Nothing Special
From what I've gathered, the biggest advantage to a twin stick is that you can drive whichever axle(s) you want in whatever gear you want. It gives you the option of being in front wheel drive, low range, which can give you some maneuverability advantages in some situations.
To get that option with a twin stick you'd also need to remove the lock-out pin that keeps the shift rails from getting out of synch with each other. If you pull the pin without a twin stick you can end up with one end in low and the other in high, which wouldn't be so good. Of course you can do that with a twin stick too, but at least you have control of it.
Old Feb 20, 2014 | 09:39 PM
  #63
david00f150's Avatar
david00f150
I asked about if they were only twin sticks because I kept seeking ads for twin sticks for the np205 and wasn't sure.
Old Feb 20, 2014 | 09:55 PM
  #64
UNTAMND's Avatar
UNTAMND
Aaaah
Ok
They are single stick from factory. Simple straight push pull type.
Easily converted with a kit or some reading.
Old Feb 21, 2014 | 10:04 AM
  #65
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Late to this party already going, but my 0.02 is a twin stick is a great mod for maneuverability (front dig), fun like turning brakes on a dune buggy....
I can get married NP205 xfer case for $75 all day long in my area, $200 is crazy prices....unless fresh rebuilt and already twin sticked.
Old Feb 21, 2014 | 10:15 AM
  #66
dclack's Avatar
dclack
Just to clear up some terminology here... all NP205s and D20s have two (2) shift rails (front and rear), but they are coupled by a bar to allow a single shifter (factory) to manipulate both rails. This is what makes twin sticks possible. Now you have one shifter per rail allowing you to independently engage either axle. Most (if not all) chain driven tcases only have one shift rail, and therefore, cannot be twin sticked.
Old Feb 22, 2014 | 01:49 PM
  #67
david00f150
Just found an AOD in the junkyard in an 88 bronco. Do I need the adapter between the transfer case and the tranny?
Old Feb 22, 2014 | 01:50 PM
  #68
david00f150
Looks like a bw transfer case
Old Feb 22, 2014 | 01:52 PM
  #69
david00f150
Also should I grab linkage or anything?
Old Feb 22, 2014 | 02:28 PM
  #70
UNTAMND's Avatar
UNTAMND
Yes you need the "adaptor" between the transfer case and transmission. That's actually the tail shaft housing.
You'll be adapting the trans to the bronco but getting some linkage wouldn't hurt.
Old Mar 12, 2014 | 07:58 PM
  #71
david00f150
Hit a major snag and you y'alls help again. I got my AOD 2 weeks ago out of an 88 full size bronco with the adapter between it and the bw case. I finally got my np205 today and when i got home they dont mate up. One of the shift rods on the transfer case is in the way between where the two flanges for the trans and transfer case should bolt together.
Please help!!!
Old Mar 12, 2014 | 08:05 PM
  #72
david00f150
Old Mar 12, 2014 | 08:24 PM
  #73
UNTAMND's Avatar
UNTAMND
It never occurred to me the shift lever was potentially in the way.
This guy is using a ford np205 in a chevy. But hopefully it pertains to you as well.
See if you can just clearance the adapter to get it to fit. Doesn't look too bad.
How to Adapt a Ford NP205 Transfer Case to a Chevy TH350 Automatic Transmission Using Mostly Factory Parts
Old Mar 12, 2014 | 10:40 PM
  #74
dclack's Avatar
dclack
Yes, you need to notch the tailhousing, just like in the second pic in the link UNTAMND posted. You have to do the same thing to the ZF.
Old Mar 13, 2014 | 12:53 PM
  #75
chrlsful's Avatar
chrlsful
it's a system, needs prts to match for a chosen application
"...clearance..."
"...notch..."
get a 4.5 inch grinder (welder's grinder) with a cut off wheel, slice a sm. bit off the housing, grind a dent in, etc...
Didn't view the attachments (on dial-up here) but wont he need to customize the current or build a new X-member for that tranny?
Such a thread I forgot what motor...
(some kinda BW transfer [1350?] & an AOD.
hummm this is getting interesting.
Is this for street application? heavy rock crawlin? mild trail, muddin? What's the vehicle application)?
Keep talkin...
