1966 - 1977 Early Broncos
C6 in an E.B.
Old Feb 16, 2014 | 09:25 AM
  #46
UNTAMND's Avatar
UNTAMND
The first one from a bronco should be mated to trans, and second one is bolted to trans. But for $600 bucks you're out of your mind. These transfer cases rarely go bad unless they are run without oil. They are virtually indestructible.
Look locally, craigslist or a super deal on eBay. This thing weighs like 80 pounds. It costs a fortune to ship. So figure that into your purchase price.
Just keep looking.
Have you found a 4x4 aod yet. They are in 1/2 ton trucks from early 80s to late 80s.
Old Feb 16, 2014 | 09:37 AM
  #47
UNTAMND's Avatar
UNTAMND
351w with transmission and t-case
May be an aod
Old Feb 16, 2014 | 07:15 PM
  #48
david00f150's Avatar
david00f150
Just keep looking.
No not yet. Gonna try and hit the salvage yards one afternoon this week. How many bolts does the AOD pan have for easy id?
Old Feb 16, 2014 | 08:57 PM
  #49
Nothing Special's Avatar
Nothing Special
From earlier in this thread:
Originally Posted by dclack
Old Feb 18, 2014 | 09:46 PM
  #50
david00f150
Having trouble finding a 4x4 AOD. Also no luck on a np 205. Could you possibly puta bigger transfer case if you had a body lift?
Old Feb 18, 2014 | 09:57 PM
  #51
Nothing Special
From my understanding it's the frame rail spacing that's the problem. Bronco frames are just a lot narrower than most truck frames. To fit a wider t.case in you'd need to offset the driveline to the right, clock the t.case down, or notch out the frame to make clearance. Any of those is a BIG project to get anywhere close to reasonable, and I wouldn't recommend any of them.
Old Feb 18, 2014 | 10:23 PM
  #52
david00f150
I definitely agree on not offsetting driveline or notching frame. Not worth the trouble! Just trying to think outside the box.
Thanks for the input.
Old Feb 19, 2014 | 12:01 AM
  #53
UNTAMND's Avatar
UNTAMND
Keep looking....
Did you call or email the guy with the 351 I linked you to. He's next door to you. All you need is the trans but worth the call.
Old Feb 19, 2014 | 12:05 AM
  #54
UNTAMND's Avatar
UNTAMND
Guy wants $200 but I'd call and ask if he'd take 100. He's got 2 more and doubtful he will sell what he has at 200
78-79 bronco castiron transfer case
Old Feb 19, 2014 | 06:16 AM
  #55
david00f150
Thanks for the link! I just emailed him. That's should be a np205?
Old Feb 19, 2014 | 09:25 PM
  #56
david00f150
Are all np205 cases twin shifters?
Old Feb 19, 2014 | 09:38 PM
  #57
david00f150
Also any good recommendations on maybe just buying a new AOD? Instead of buying someone else's problem.
Old Feb 19, 2014 | 10:49 PM
  #58
UNTAMND's Avatar
UNTAMND
NP205 is a single stick transfer case. You can modify it to be a twin stick easily though.
The 78-9 will be an np205. 80 was the start of the np208. Click on that fordification link again and review what vehicles the np205 came in and it's identification features for when the guy sends pics to you.
A new aod would be fine if it's in the budget.
Research some junkyards or salvage yards in your area. There's gotta be someplace that has older trucks.
Old Feb 19, 2014 | 10:54 PM
  #59
UNTAMND's Avatar
UNTAMND
Pickapart.com
Auto Salvage yards in Baton Rouge Louisiana - Car & Auto Junk yards in Baton Rouge LA - Nearby Junk yards
Check them out
Old Feb 20, 2014 | 07:05 PM
  #60
david00f150
What's the advantage to a twin stick?
