Cody test
Old Mar 13, 2015 | 01:06 PM
  #31
oldboots1950's Avatar
oldboots1950
Thank you for providing information on how to perform this test. I found this very useful.
Old May 5, 2015 | 08:56 AM
  #32
frambin's Avatar
frambin
Will a regular air compressor be sufficient for this test? Mine only builds up to 100 psi maybe 105.
Old May 5, 2015 | 12:38 PM
  #33
F250_'s Avatar
F250_
Probably so. Costs nothing to try.
Old May 5, 2015 | 01:28 PM
  #34
TheBigBee's Avatar
TheBigBee
Glad this was brought up I am trying to figure out a no start with no ICP and I am leaning towards the HPOP being bad but this will be a good test before I spend the money for the new one.
Old Mar 27, 2017 | 09:18 AM
  #35
freesoul's Avatar
freesoul
Can anyone help me identify the locations that I would apply air pressure to the HPOP? photo would be key. TIA
Old Mar 27, 2017 | 09:30 AM
  #36
timmyboy76's Avatar
timmyboy76
You're not putting air into the hpop, but air in the hpop lines. Remove the VC's and disconnect hpop lines AT the HPOP. Introduce a few lbs of air into the line and watch for bubbles around the injectors
Old Mar 28, 2017 | 12:41 PM
  #37
freesoul's Avatar
freesoul
I was under the impression this test was done without the need to remove the VCs?
Old Mar 28, 2017 | 01:52 PM
  #38
Dan V's Avatar
Dan V
Just above the top lip of the VC's there are two ports, one port has the HPOP line attached, the other (placed symmetrically) has a plug.....remove said plug and apply air there.
Old Mar 29, 2017 | 02:57 AM
  #39
Tugly's Avatar
Tugly
You can leave the VCs on until you have one oil rail leak down. Once you have a leaker, you need to find the source - which usually involves looking under the VC.
PapaBearYuma
Jul 27, 2017 03:44 AM
IB Valencia
Oil & Lubrication
Jun 7, 2013 12:52 PM
52 5 star
Jan 28, 2012 09:05 PM
Earl
91
Jan 1, 2010 11:40 AM
