SPEEDOMETER PROBLEMS---HELP!!!!
Old Feb 4, 2014 | 06:47 PM
78 Ford F150 460's Avatar
78 Ford F150 460
I would guess also you do/did not have the white clip on all the way and the cable is slipping in and out of the collar? Swap back in the KPH and that will tell you if its a gauge cluster or the cable issue. If you did not remove it from the trans then should not have any issues down there.
Never thought about the clip not being seated. Guess I'll just have to put it back in and pay attention a little better and see what happens. Thanks for the advice...
Old Feb 4, 2014 | 07:15 PM
Broncobobby76's Avatar
Broncobobby76
My 76 bronco starts jumping erratically at about 60 mph. It also seems worse when it is cold...really weird. The odometer however seems completely Un affected by the jumping. Good luck.
Old Feb 4, 2014 | 07:39 PM
czaroc's Avatar
czaroc
I don't think the clip is replaceable. Not 100% sure though.
Old Feb 4, 2014 | 07:53 PM
410 Highboy's Avatar
410 Highboy
My speedometer went crazy above 30 mph . I replaced the cable and housing . Cable was too long so I took it to a speedometer shop . He shortened the cable . Still goofy acting . So I had the speedometer rebuilt .He told me that the jewel and the magnets wear out on Fords . Everything back together now and working .
Old Feb 4, 2014 | 08:58 PM
78 Ford F150 460
Who rebuilt your speedometer (company??) and how much did he charge? Does it work flawlessly now, without jumping around? Mine jumps around too. What is the cause of this?
Old Feb 4, 2014 | 09:25 PM
410 Highboy
Local shop in Colorado Springs . $88 .Ebay has them for $50 to $125 .
Meridian_Mike
Jan 18, 2019 02:19 PM
Amish65F100
Apr 5, 2017 08:37 AM
I-6 Power
Nov 28, 2012 07:51 AM
BPofMD
Jun 16, 2011 01:52 PM
6banger 150
Mar 26, 2008 10:12 AM
