Replacing Frame Rivets
Old Feb 7, 2014 | 11:13 AM
petemcl's Avatar
petemcl
Originally Posted by ALBUQ F-1
SS bolts with SS nuts are likely to gall.
You are right Ross which is why I used self locking nuts with nylon locking which minimizes galling.
Here in road salt country I am very concerned about corrosion. This truck came from Minnesota and has lots of rust.
Old Feb 7, 2014 | 07:20 PM
Samsn4's Avatar
Samsn4
So something like this? 1/2"-13 x 2" ASTM A325 Galvanized FQI Structural Bolt w/Nut | Fastenal
It's only about $0.25 more per bolt as compared to Grade 8
Old Feb 7, 2014 | 08:07 PM
clintonvillian's Avatar
clintonvillian
You guys are overthinking this. Grade 8 is fine, Grade five is fine. You can even use plain non coated bolts and throw a coat of paint over them.
A325 bolts are typically found in bridges and such, not in vehicles. Frame bolts see more tensile load than anything, tensile strength of the grade 5 and 8's is far superior to the actual surrounding frame material. That being said you are more likely to "tear" or deform the frame steel around the bolt than break the bolt.
Rivet materials are typically softer than grade 8's and grade 5's, the only difference is the interference fit. This has been debated to death in multiple threads. As far as rivets vs bolts go think about it like this, all new bridges are designed using bolts in tension and not rivets..............
Old Feb 7, 2014 | 08:26 PM
cstempert's Avatar
cstempert
Rivits aren't that hard if you think it through. Adjustable buck rods (like a spreader bar) can be made for most of the locations on a frame.
For crossmembers a buck under the frame with the trucks weight is sufficient.
We just riveted 3/8 and 7/16" rivets on a 55 C900 and it want too difficult. 5/16" on an half ton would be easier Once you heat up the rivet to bright red it squishes with minimal effort with a impact hammer.
Old Feb 7, 2014 | 08:29 PM
Samsn4's Avatar
Samsn4
sweet, thanks.
Old Feb 7, 2014 | 10:16 PM
havi's Avatar
havi
I'll have the Roast Duck
Nuts and bolts have better pulling 'resistance' (harder to break), rivets have better sideways 'resistance'. So if the bolts are horizontal, like leafspring brackets for instance, the up and down bouncing of the truck on the road will keep pushing into the sides of the bolt where it goes through the frame and bracket.... this is where you do not want threads, but a solid shank should be fine. Rivets will resist this wear the best. However, all the bolt needs to be, is stronger material than the frame itself, cuz then it'll be the frame holes that will wallow. Is a grade 5 or 8 bolt stronger than the frame material? Probably yes. Is a rivet the tightest bond in all directions, reducing lateral movement? Yes. Does it matter on a half ton pickup? Probably not, but on a big truck carrying tons of something, it probably does.
Old Feb 7, 2014 | 10:27 PM
clintonvillian
The example you just stated using the hangers is a common misconception people have.
Those bolts/rivets should not experience shear as you described. A proper connection transfers the force between the hanger and frame through friction of the two mating surfaces. The friction is applied by the proper tension placed on the bolt.
When the bolt or rivet is not tight enough then you experience a shear load on the bolt/rivet and either the bolt or frame fails.
Old Feb 7, 2014 | 10:44 PM
havi's Avatar
havi
Makes sense. I understand what you are saying. And it would probably last the lifetime of the truck.... especially a half ton.
loganb
Apr 26, 2017 12:49 PM
CAMiniTruck
Apr 16, 2012 09:33 AM
ErrorS
1978 - 1996 Big Bronco
Aug 29, 2011 11:53 AM
Bikeitswift
1997 - 2003 F150
Jul 31, 2004 11:08 PM
Craigwell
Jun 30, 2004 09:34 PM
