center console removal?????
Old Feb 1, 2014 | 10:26 PM
goober22's Avatar
goober22
I am trying to remove the center console in my 1996 explorer limited 4x4 4.0 liter v-6 . Is there some type of trick or hidden fasteners? I am trying to replace the heater core and any pointers would be helpful. Thanks
Old Feb 2, 2014 | 09:26 AM
shorod's Avatar
shorod
Here are the text steps from the factory service manual for the "high series console" which I assume your Limited has. If you want the full manual section, send me a Private Message with the request, vehicle specifics, and an e-mail address for you that can accept PDF attachments.
  1. Using hand pressure, free four (4) snapping clips attaching console finish panel (04567) assembly (message center will be removed with finish panel).
  2. Disconnect four (4) electrical connectors to message center.
  3. Remove console panel control finish panel by releasing six (6) snapping clips.
  4. Disconnect electrical connector (light bulb with blue filter) for console ashtray.
  5. Remove screw in main wire connector to disconnect, then pull connectors apart (screw is located in the instrument panel side of connector).
  6. Remove two (2) screws attaching console to instrument panel.
  7. Remove two (2) screws attaching console to floor pan.
  8. Slide console rearward to release rear bracket (front console bracket is money clip shaped and will release as console is slid rearward.
  9. Lift console from vehicle.
For installation, follow removal procedure in reverse order
-Rod
Old Feb 2, 2014 | 01:37 PM
goober22's Avatar
goober22
Thanks for the reply Rod, my console has the CD changer inside the armrest. I have removed the CD changer and plastic box that it was mounted in as well as the rear heater controls and every bolt and screw I could find and now I am thinking I am just not forcing it hard enough.
I will send PM for reading material, Thanks
king-david
Sep 6, 2019 04:54 PM
bubba_3711
Apr 1, 2014 10:31 PM
micdeole
Feb 3, 2014 12:11 PM
EljayK004
1983 - 2012 Ranger & B-Series
Nov 15, 2005 11:07 AM
98BIGBODY
Feb 20, 2003 11:41 PM
