Vacuum switch on 7.3?
Old Feb 1, 2014 | 08:22 PM
Faster71's Avatar
Faster71
Is their a vacuum switch on a stock 2000 ex 7.3 and if yes where??
I took all the lines off the vacuum pump and plug the line coming out of the vacuum pump and it still did not turn off.
Old Feb 2, 2014 | 12:39 AM
Bonanza35's Avatar
Bonanza35
I your vacuum canister leaking?
Old Feb 2, 2014 | 07:40 AM
Faster71's Avatar
Faster71
I have removed the line going to the vacuum canister and the pump still runs
Old Feb 2, 2014 | 07:51 AM
Pikachu's Avatar
Pikachu
If you remove the line from the pump to the vacuum reservoir and put your fingertip over the port on the pump, it should stop running almost immediately. If it doesn't, it's probably time for a new pump.
Old Feb 2, 2014 | 08:28 AM
Tugly's Avatar
Tugly
While I haven't confirmed this, I believe the vacuum switch is internal on the pump... this would be in line with Pikachu's feedback.
Old Feb 2, 2014 | 01:36 PM
Bonanza35's Avatar
Bonanza35
What they said. Never heard this happening before but sounds right.
Old Feb 2, 2014 | 08:26 PM
Faster71's Avatar
Faster71
Ok thanks for the info I will get a new pump and take the old one apart and report back thanks.
Old Feb 18, 2014 | 08:18 PM
Faster71's Avatar
Faster71
vacuum pump and sensor
this pump would only pull 10" of vacuum
Old Feb 19, 2014 | 04:43 AM
Tugly's Avatar
Tugly
I wonder if I see a trend of everybody gutting components.
That's great info! Reps.
Nabors
Aug 3, 2014 12:58 PM
Faster71
Feb 18, 2014 08:15 PM
jts0385
Dec 27, 2012 03:32 PM
mh34444
May 29, 2010 06:40 AM
my4604x4
Sep 3, 2008 07:52 AM
