'07 F150 4x4 4.6L, EGR location
Old 02-17-2014, 06:20 PM
Scratcha's Avatar
Scratcha
Scratcha is offline
Hey y'all,
Where is the EGR valve on the 4.6, approximately?
I had a check engine light scanned at Autozone today.
Exhaust Gas
Recirculation Flow
Insufficient
Detected
That was what the scanner read on its display.
Sounds like an EGR, according to the associate.
Any thoughts?
Old 02-18-2014, 06:51 AM
JWA's Avatar
JWA
JWA is online now
Received 1,394 Likes on 1,103 Posts
What was the trouble code they retrieved?
Old 02-18-2014, 07:08 AM
Scratcha's Avatar
Scratcha
Scratcha is offline
I didn't see the actual code on the scanner.
He was using an Actron scanner.
The quick test results were:
Exhaust Gas
Recirculation Flow
Insufficient
Detected
MIL
I found the EGR location on the motor.
I probably just have to clean the EGR and ports.
But at 60,000 miles maybe I should replace the EGR.
Old 03-02-2014, 08:27 AM
Scratcha's Avatar
Scratcha
Scratcha is offline
Well, I replaced the EGR yesterday; So far so good, The check engine light cleared.
The original EGR looks pretty clean, I was surprised I didn't see any clogged ports.
The EGR pipe that connects the EGR to the catalytic converter was a Bear to get loosened!
I was worried about cracking the intake manifold, trying to get it loose.
Old 03-04-2014, 11:58 AM
Scratcha's Avatar
Scratcha
Scratcha is offline
Good 'ole PB Blaster saved me a lot of grief; I don't know if would've gotten it loose.
It amazes me that 4 autoparts stores didn't have the EGR in stock. I guess if I would've ordered one ahead of time; I could've saved a little cash.
I bought a OE Motorcraft replacement from a local Ford dealership for $180.
hambone7
Modular V8 (4.6L, 5.4L)
18
09-20-2007 07:45 AM
the_sharkster
03-07-2007 02:04 PM
trevorr
1997-2006 Expedition & Navigator
11-22-2006 10:34 AM
KFellers
1997 - 2003 F150
04-19-2005 10:21 AM
yyz87
07-06-2003 11:27 PM
Quick Reply: '07 F150 4x4 4.6L, EGR location
