Gear ratio identification
Old Jan 30, 2014 | 06:31 AM
okie72's Avatar
okie72
I am going to look at a front and rear end the guy says they have 4:10 gears but no tags on them. My question is how many teeth should the ring gear have and how many should the pinion have so I can make a positive i.d. before I buy. Also they are out of a 78or 79 supercab f150. Did any half tons come out with 4:10 gears?
Old Jan 30, 2014 | 09:29 AM
fitzmotor's Avatar
fitzmotor
The gears should have the ratio stamped on the ring gear, if not just mark the ring gear and the pinon, rotate the pinon 4.1 times and the ring gear should make 1 full revolution.
Old Jan 30, 2014 | 12:54 PM
okie72's Avatar
okie72
The last one I took apart did not have the ratio stamped on the ring gear it was smooth all the way around. Can you count the ring teeth and the pinion teeth and divide them?
Old Jan 30, 2014 | 12:58 PM
Filthy Beast's Avatar
Filthy Beast
Yup!....10 characters
Old Jan 30, 2014 | 01:07 PM
85e150's Avatar
85e150
Count and divide is the way.
This here shows tooth counts for many ratios. 41/10 is your magic combo:
Richmond Gear Ford Ring & Pinion Sets - Free Shipping on All Orders @ JEGS
Helpful tips and info, fwiw:
Tech
Old Jan 30, 2014 | 02:08 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
AXLE code stamped on the Warranty Plate, located on the left door face below the latch.
Old Jan 30, 2014 | 09:02 PM
okie72's Avatar
okie72
Thanks for the info guys this helps a lot!
Old Jan 31, 2014 | 06:27 PM
Gbark's Avatar
Gbark
Not to but my code on the door is 46j. Anyone know what rear end this is?
Old Feb 2, 2014 | 09:46 AM
tabascom16's Avatar
tabascom16
The easy way to do it:
Put the transmission in neutral and jack one tire off the ground.
Rotate the wheel one revolution and count how many revolutions the driveshaft makes. Driveshaft rotation is HALF of the gear ratio.
About 1 3/4 turns - 3.55
About 2 turns - 4.11
About 2 1/4 - 4.56
Never trust tags as over the years someone could have changed the gears and put the tag back on anyways.
79f100six
Apr 16, 2008 09:10 PM
Encho
1978 - 1996 Big Bronco
Mar 4, 2008 11:25 AM
HUCKSTER-USA
Nov 18, 2006 08:02 AM
jnyreb69
Nov 7, 2004 01:33 PM
TC_xplorer
Sep 12, 2002 05:42 PM
