Quick and easy gear question
Old Apr 16, 2008 | 08:24 PM
79f100six's Avatar
79f100six
i was just wondering if the more teeth a gear has the higher the gear ratio or is it the other way around.
Old Apr 16, 2008 | 09:10 PM
sclariat's Avatar
sclariat
Count the number of teeth on the driven gear, divide by the number of teeth on the drive gear. Like if your crown or ring gear has 39 teeth and your pinion gear has 13 teeth your ratio is 3:1. In other words the pinion has to make 3 revolutions before your wheel make 1.
You can't just count one gear to determine if you have a higher ratio than another gear. GM for example has two ring gears that have 41 teeth but the pinion that matches to one has 11 teeth while the other has 12. They amount to two different ratios. one being 3.42:1 while the other is 3.73:1
Kerrie
Feb 4, 2008 05:07 PM
BigMattXXL
Jan 6, 2003 09:33 AM
Ford Truck Racer
Sep 30, 2002 10:20 AM
Varnish
Jun 25, 2002 02:52 PM
FTE Ken
Jan 2, 2002 04:16 PM
