Rocker patch panels?
Old Jan 29, 2014 | 08:24 AM
RKraft's Avatar
RKraft
Is there rocker panel patch panels available for our EX's? Mine needs just the corner section on both rears. The drivers side has a small hole in it & the passanger side is starter to get the same way. I found these panels some where but now can't seem to find them again. Does the Super duty supercab corners work they look the same? Here is a link to these corners 1999-07 HD250/350 Lower Rear Door Pillar (Super Cab) Driver Side
Randy
Old Jan 29, 2014 | 03:44 PM
1 Excursion camper's Avatar
1 Excursion camper
Glad you brought this up. My left side rocker below the rear door has rotted through. It looks like i can easily replace the entire piece as all the spotwelds and the panel is on the outside. The other side looks solid still. I'll have to get a camera down in there to check it out.
Old Jan 29, 2014 | 05:00 PM
1 Excursion camper
Old Jan 29, 2014 | 09:08 PM
RKraft's Avatar
RKraft
Found the panels I posted a link to are different and the company said they are not made aftermarket. I have a friend that works at a body shop checking on them I will post once I find some thing out. My left side to is rusted through, the right side is rusty but not through yet. Actually have a hole on left side wheel well right into the rocker which I think caused the rocker to rust. The snow, salt and other crap sits there between the quarter panel lip and wheel well. So check yours 1 Excursion camper for any other holes. As soon as I hear from my buddy I'll let you know.
Randy
Old Jan 29, 2014 | 09:42 PM
garryk6's Avatar
garryk6
I need the inner rockers that the running boards bolt to. My out rockers are still ok, but I do need to attend to the bottoms of both front doors too...
If anyone can find part numbers for he inner rockers I'd be very interested?
Thanks!
Garry in Kodiak
Old Jan 29, 2014 | 09:52 PM
neilc88's Avatar
neilc88
Also looking for the front bottom inside door sheet metal. Rusted a 2" hole on the inside.
Subscribing.
Old Jan 30, 2014 | 08:17 AM
ExploringNH's Avatar
ExploringNH
No rear rockers available for the Excursion. I made my own and it took ages. Lots of curves and angles to deal with in that back corner.
The inners (where the running boards bolt to) are just flat. Use some sheet stock and weld it in.
The fronts doors and rockers should be the same as super duty trucks, but someone might want to double check this.
Old Jan 30, 2014 | 05:34 PM
1 Excursion camper
Thanks. Yes i religiously rinse my wheelwells and undercarriage. I fixed the doors a couple years ago and they have not shown signs of popping! The only rust i have that is visible is the left rear rocker. From what i can see inside the right rocker it is clean.
Thanks for the info. I wonder if a rocker from a crewcab will work?
Old Jan 30, 2014 | 06:27 PM
Bodaddio's Avatar
Bodaddio
Might help you out. Ford Repair Panels - 1999-07 Ford F250/F350 (Super Duty)
Old Feb 2, 2014 | 09:19 PM
pennsylvaniabo's Avatar
pennsylvaniabo
Has anyone tried to use a rear super cab panel in the rear door corners? they look similar?
rustfixer
Jan 24, 2019 11:32 AM
CaptGuz
May 23, 2007 09:03 PM
Old Rust Bucket
Paint & Bodywork
Feb 19, 2007 05:34 PM
RLord4268
Paint & Bodywork
Mar 17, 2006 07:38 AM
