Been pretty cold in Southern MD this past week. So I remote start my X when it was 8°F outside. Now the ONLY fuel pump I have on my X is an AirDog 2. When I got in the X, I saw no fuel pressure on my pillar gauge and the AD2 no pressure yellow warning light was on. The X was still running and running smooth. That was a head scratcher. So I dropped it in gear and away I went. For 4 days drove it like that and finally Sunday it qiut. Would try to start but just would not catch. That I attributed to getting the p2285 ICP code. Replaced the ICP yesterday while it was 55°F. Tried to start and still had no gauge or lite fuel pressure indications. Check the AD2 fuse and it was blown. Replaced the fuse and I got fuel pressure and a good start.
HOW DID IT RUN FOR 4 DAYS WITH NO FUEL PRESSURE???????
Yeah, as soon as I back tracked what happened, the lite went on. I was surprised that even under a fairly hard accel, it did not bog down or stop. Thanks for the info.
I'm not sure. I'm guessing the AD2 with a smaller micron filter and it being 8°F outside made it hard to push the diesel. It was 9° this morning and started right up showing 90 psi fuel pressure. That eventually dropped back to 70 psi.
