Need help on year model !
Old Jan 27, 2014 | 08:56 AM
maximusfd's Avatar
maximusfd
I have a friend that gave me some parts for a 7.3 powerstroke. He gave me a turbo with a "x" pipe , I think it is called , a/c compressor , and an alternator. After looking at the turbo I noticed it looked different than the one in my 2001 7.3. On the "x" pipe there is not a spot to put an AIH. On the casing right before the v-clamp that goes to the "x"pipe there is a marking that says 1.10A/R Thanks for the help.
Old Jan 27, 2014 | 10:51 AM
clux's Avatar
clux
Sounds like it's probably from a 95-97 pickup.
Old Jan 27, 2014 | 02:43 PM
Pikachu's Avatar
Pikachu
It's could also be early '99. The early '99s had no intake air heater, and a 1.10 A/R compressor housing with 4 bolts, with a 0.84 A/R turbine housing (unless it's a van turbo). The turbo pedestal is also lower on the early '99 than the 99.5 up. The A/C compressor should be the same. If you can post a couple of pictures, that would probably help nail it down.
Old Jan 27, 2014 | 04:30 PM
maximusfd's Avatar
maximusfd
I should have not said no EBPV. I do not have the pedestal. I took that comment out. My friend said he thought it came out of a 99 or 2000 truck. I figured the a/c compressor was the same. I put the clutch on my compressor since mine has fallen off. It works so far. So is there any use for the turbo for my truck ? I already bought a wicked wheel and intalled it in my truck before i got this extra turbo. I would take pictures. But , do not know how to up load them. Pikachu you are correct on the four bolts. Thank you.
Old Jan 27, 2014 | 04:58 PM
Pikachu's Avatar
Pikachu
If your friend said it was 99 or 00, it must be early '99.
ltl_jrw
Jan 4, 2012 08:48 AM
fordpride
Apr 23, 2011 07:55 AM
MauleOne
Sep 19, 2010 11:08 AM
slk133
58
Mar 27, 2008 05:55 PM
sturzinator
Mar 28, 2007 07:10 PM
