351W Timing concerns
Old Jan 26, 2014 | 06:13 PM
bruno2's Avatar
bruno2
I ran this round quite a bit a year or so ago. I still haven't gotten the answers I need and I cant figure it out.
I have a roller cam in the motor. It's not aggressive enough to need an adjustable timing set installed. When Gary Lewis and I put a degree wheel on it straight up was where it needed to be. We set the initial timing at 7° BTDC according to the vacuum gauge. It has about 30° over all. The dizzy has a mechanical advance only.
Where the dizzy is at the starter cant hardly turn the motor over to start it. When it does the relay on the firewall smokes and so does the ground terminal on the battery. So that's not right somehow.
I need some suggestions please. I don't know where to go or what to do.
Whenever I back the timing off to 0° or 2° BTDC the motor turns just fine when starting, but pings and diesels as well as wants to keep running when I kill it.
Old Jan 26, 2014 | 06:32 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
I wonder if the timing marks are off. I'd try turning the engine by hand to TDC on #1 and checking the mark.
Old Jan 26, 2014 | 06:51 PM
bruno2's Avatar
bruno2
We did and it was on. I am sure about the engine timing right. We used a dial indicator to find absolute TDC of #1 and then like I was saying used a degree wheel to make sure the engine timing was right for the roller cam. So that part is correct.
Old Jan 26, 2014 | 09:00 PM
Conanski's Avatar
Conanski
What do the spark plugs look like? If the motor is running rich that extra fuel washes oil off the cylinders walls and that makes hot starts really difficult.
Old Jan 26, 2014 | 09:24 PM
bruno2's Avatar
bruno2
I will check tomorrow. The plugs are almost brand new. They have about an hour or hour and a half of running time on them. The exhaust doesn't really smell rich like burning your eyes. I don't know if the plugs will tell us anything, but I will check a couple.
Old Jan 27, 2014 | 03:58 PM
bruno2's Avatar
bruno2
I pulled 1 and 4. They looked fine. Then again there is not a lot of run time or miles on them either.
I am running a procomp dizzy with mechanical advance only and a streetfire ignition module. I don't believe either has a start retard function, but still 7° BTDC shouldn't be doing this.
Old Jan 28, 2014 | 05:39 PM
BaronVonAutomatc
What's the factory timing on a 351W? It's got to be 8 or 10° BTDC?
At what timing does it start to push back against the starter? 0-2° is too little, 7° is too much then maybe 3-5° is the spot.
There's something very screwy going on. Have you checked the internals of the dizzy to see if anything is sticking or out of place?
How much vacuum are you pulling at 7° and at 0-2°?
Old Jan 28, 2014 | 06:08 PM
bruno2's Avatar
bruno2
I haven't checked the internals of the dizzy, but they are certainly suspect right now. I don't trust the brand of the dizzy and I am about to just go back with a new DSII set up and ditch the aftermarket dizzy and module. Then I will report back.
Old Feb 21, 2014 | 05:21 PM
Rusty_S's Avatar
Rusty_S
My 351w says on the spec decal 14* +or- 2*. I currently have my timing set at 16* timing base and when the vacuum modulator (can't remember official name) is plugged in the vacuum advances to 20* timing at idle. Vacuum advance on distributor at idle produces no vacuum as its ported vacuum.
Start up is just fine at this setup.
rsm688
Jun 24, 2015 06:54 AM
bruno2
16
Jan 26, 2014 10:14 PM
46069dord
Jul 16, 2008 08:09 AM
70T351W
Apr 20, 2005 07:14 PM
Feeop
Aug 6, 2004 01:07 PM
