Quick key question.....
Old Feb 2, 2014 | 10:44 PM
r2millers's Avatar
r2millers
Originally Posted by Mark62
Does the plain metal key work if you are not carrying a Pats key?
Nope. It will not start the engine, just turn it over if cut to cylinder.
Old Feb 3, 2014 | 06:57 AM
projectSHO89's Avatar
projectSHO89
That is how it is expected to work, but the question was specifically asked of "teamlx88" and HIS particular truck.
Old Feb 3, 2014 | 10:41 AM
r2millers's Avatar
r2millers
Sometimes that obvious, just flew over my head.
Thx.
Old Feb 3, 2014 | 02:15 PM
teamlx88's Avatar
teamlx88
Yes the plain metal key will start the truck by itself. I thought there was a PATS key hidden somewhere but I now think someone messed the anti theft up good. My alarm doesn't work and the theft light on the dash doesn't blink either. Unless I remove the ground wire from the radiator support on the drivers side. Then it works, but something buzzes in the under hood fuse box so I can't leave it that way
Old Feb 3, 2014 | 11:41 PM
TheCurtster's Avatar
TheCurtster
So if I'm following this correctly, I can get a couple of cheapo keys cut and it'll start my truck just fine if I attach the one remaining chipped key I have to the lock cylinder? How close does the $100 key have to be to the lock for this to work? Guess how excited I am to spend $100+ for a new key?
Thanks for the help!
Curt
Old Feb 4, 2014 | 07:56 AM
projectSHO89
I pull the transceiver ring off the housing, put the key inside the loop and secure it in place, then secure the whole thing out of sight away from the cylinder.
toys4dlr
Sep 21, 2024 06:44 AM
Dishman
Mar 21, 2018 09:10 PM
tseekins
2009 - 2014 F150
Dec 20, 2015 10:55 AM
tapout
1997 - 2003 F150
Sep 14, 2006 06:49 AM
nbk6ch
Mar 3, 2003 08:51 PM
