Another torque converter question.
Old Jan 23, 2014 | 07:08 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by cleatus12r
Don't worry about a non-PWM (on/off) torque converter clutch solenoid and related pump valving in a 7.3L or V-10 transmission. The ONLY factory non-PWM 4R100s were behind the V-8 model 4r100 transmissions.
That is not my recollection. It has been a decade and a half, though.
Hmmm.
I can program a stock 4R100 using an XLEx PCM to essentially act as an on/off setup...watch out for the mule kicking the seatback at 45 MPH under normal acceleration. I recently (as of about a week ago) did some live tuning on an E99 with an XLE4 and BTS using an aftermarket on/off setup (pump and solenoid). Don't try to make the stock PWM mapping work with one of those.
That shows that the pump that was in the trans didn't have the restrictor that was incorporated in the on/off pumps. It doesn't tell me that the original pump didn't have that.
Mark has said many times that he wasn't involved with the 4R100. While his technical expertise concerning automatic transmission operation and theory is unsurpassed in the forum world, the tuning aspect (as well as those who have rebuilt a few) says otherwise.
I was never assigned to the 4R100 department. Contrary to what many of said on the forums I did not design the 4R100, nor did I ever design ANY transmission.
I did work in a group that supplied transmissions (E4OD, then 4R100, then 5R110) to an off road race team. We won many races including the Baja 1000 and several championships. For me this was a part time assignment. I did the transmission tuning for this.
As my full time work at Ford I worked on the tuning for the AX4S (Taurus/Sable/Continental/Windstar,) then I worked on transmission OBDII, then the 5R55N in the Lincoln LS/Thunderbird, then I worked on tuning the 5R110 behind the 6.0L, then I worked on improving transmission cooling and cooling procedures before bailing out in 2007.
Old Jan 23, 2014 | 07:37 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Originally Posted by Mark Kovalsky
And of the different solenoid and of changes in the pump body circuits..
Is it just a single restrictor in a single pump body circuit, or are there plural changes?
__________________________
Originally Posted by Tim J
The earlier ones had ON/OFF TCC. They went to a PWM(pulse width modulation) for variable torque converter lockup in 2000ish. Dont know exactly when. Anyway, this may require a PCM swap. Does anyone know?
I know exactly when. All 4R100 transmissions are PWM. All E4OD transmissions are on/off lockup. The first '99 had a 4R100, the E4OD ended with the old body style trucks.
There was an early '99 and a late '99. The late '99 is a direct replacement. The early '99 does have an important difference.
The early '99 used an on/off torque converter lockup solenoid. The later trans (and for the rest of the 4R100 run) had a Pulse Width Modulated (PWM) solenoid. There was a hydraulic difference inside the pump body that went along with this change.
If you put an early '99 trans in your truck I don't think the torque converter will lock.
You can find out which solenoid is in the trans with an ohm meter and a wiring diagram. The resistance across the two pins of the on/off solenoid is about 20-30 ohms, the PWM is less than 5 ohms. This is going from my somewhat faulty memory from more than a decade ago, but I think I'm right.
Mark, looking at what you have said here a couple of years ago, does this refresh your recollection about the Early 99 Super Duty body style with a 4R100? It almost looks as though you have called it both ways.
Believe me, I understand about not being able to remember things as I get older. Since this question has come up often enough over the years, it occurred to me to try and look back in time, to see what you might have said in the past, when it may have been fresher.
Can't say I arrived at anything definitive... it's about a 50-50 split. But one thing is clear... it would be nice for people faced with ordering a transmission or torque converter to actually know the difference or know how to determine the difference, because this issue always comes up.
______________________________
And for the benefit of folks like me who need all the help they can get towards understanding an issue, here are a few more posts by Mark over the last 6 or 7 years. I thought it would be neat to see them collected in the same thread, as each post reveals a tiny bit more information that helps in understanding what is going on.
The problem is that the E4OD had an on/off solenoid. When the PCM commands the solenoid on the pressure to lock the clutch it is fed through a small orifice, I think it was about 0.030". The 4R100 has a PWM solenoid that is pulsed on and off very quickly to control the clutch on. The orifice was opened to what we called wide open, which is usually 0.250" or larger. The solenoid driver in the '96 is only able to be on or off, it can't pulse. You could change the solenoid to an on/off and change the orifice back to 0.030", if that is the right number.
It is a way to control the solenoid. Earlier transmissions used a solenoid that was 100% off or 100% on. There was no in between. The on/off solenoid was turned on, and the speed of the torque converter clutch apply was controlled by an orifice.
The PWM system doesn't have an orifice in the circuit. A PWM modulates how much time it is on and off. It can run almost any percentage on vs. off to control the output pressure. The PCM controls the duty cycle of the solenoid to control the pressure to control the speed of the torque converter clutch.
Old Jan 23, 2014 | 08:13 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
And of the [/b]different solenoid... The solenoid is different between the PWM and the on-off. [/b]You can check the resistance across the solenoid without opening the trans and tell which one you have. All you need is the resistance values and a wiring diagram of the transmission connector.
What is the name of this solenoid that is different? The "TCC" solenoid?
Originally Posted by DakotaDiesal
Having issues with the whole PWM non PWM thing. Tag on transmission F81Z7000LBRM. Called the dealer with the vin number and they couldnt say just told me the code or tag was a prb-ay trans. It is out of a 99 f250 but i am trying to verify if this is PWM or not. My final question is can a non PWM be converted to a PWM? Is it more than the shift solenoid and pump? Are there other internal changes?
It has nothing to do with the shift solenoids. The difference is the torque converter clutch (TCC) solenoid and an orifice in the pump body.
As far as I know ALL 4R100 transmissions are PWM. All E4OD are non-PWM.
Below is a list of solenoid choices from Drivetrain.com. It is daunting, amidst this confusion about whether or not the 4R100 ever at one time had a Non PWM set up or not, and whether or not the solenoids are different or not.
If I were in the position of the OP, I would not know which of the last three solenoid assemblies to choose for an early 99. There are actually two more solenoid assemblies that I did not include on this list, as they were for 89-94.
TRS36420B Solenoid Assembly, E4OD (Non PWM) 95-Up
TRS36420C Solenoid Assembly, E4OD (Non PWM) (w/ Variable Delay) 95-Up
TRS36420B Solenoid Assembly, 4R100 (Non PWM) 98-Up
TRS36420C Solenoid Assembly, 4R100 (Non PWM) (w/ Variable Delay) 98-Up
TRS36420D Solenoid Assembly, 4R100 (PWM)
Old Jan 23, 2014 | 02:06 PM
Mark Kovalsky
I did call it both ways. I now believe the correct information is that the early '99 had an on/off and all the rest of them had a PWM.
I only recall one change in the pump body. The orifice with the on/off and no orifice with the PWM.
Old Jan 23, 2014 | 03:56 PM
Pikachu's Avatar
Pikachu
I guess I should ask, in the grand scheme of things, from the torque converter's perspective, does it matter if the transmission uses PWM or on/off for the TCC lockup? Is it a matter of the PWM mode causing accelerated clutch disc wear from taking longer to fully apply lockup?
I haven't checked the pump to see if there's an F8 stamped anywhere on it yet, I've been too busy fighting with the engine I'm trying to get ready to go back in it.
Old Jan 23, 2014 | 05:06 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Mark is right.
Verified through VIN with the Ford Parts Catalog.
The E99 has a restrictor orifice while maintaining a on/off torque converter clutch solenoid/valving. It doesn't matter that the PCM itself actually pulse width modulates the signal to the converter clutch though....the rate matters a bit for feel but overall, it doesn't make nearly the difference that dinking with the ACTUAL PWM valving does on the later trucks. It still doesn't make me feel any better about being able to command the PWM to "instantaneous maximum" and actually monumentally alter the apply feel though......
It's a good thing to know.
Thanks for arguing the point.
Old Jan 23, 2014 | 05:07 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Yes, it's just like a long, drawn-out shift.
They ALL have F81Z-7A130-xx cast into the housing. Don't trouble yourself removing the torque converter just to see it.
Old Jan 23, 2014 | 05:20 PM
Pikachu's Avatar
Pikachu
Well, that figures.
The converter is going to come out anyhow to haul in as a core. I guess I'll just look at the pump when I do that and see if there are any other markings on it.
Old Jan 23, 2014 | 05:32 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Well, that figures.
Let us know if the last two characters in the part number are "BA" or "CA" (denoted by "xx" in my last post).
Old Jan 23, 2014 | 05:48 PM
Pikachu's Avatar
Pikachu
I'll do that. Is it safe to assume the BA code is the early one? Thanks a lot for taking the time to look this up, BTW.
Old Jan 23, 2014 | 09:16 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Are you SURE about this? This would really surprise me.
I wouldn't expect to find that part number in my transmission, because mine has never been rebuilt, so it would not have a Z as the last letter in the four digit prefix of any part number inside of it. In otherwords, the parts would have engineering numbers, but not FCSD part numbers, which usually distinguished from production parts by the Z in the first 4 characters of the prefix. (nothing to do with remanufactured)
Old Jan 23, 2014 | 09:28 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Now that we know with confidence, and have confirmed beyond doubt, memory, and challenges, that the early 99 4R100 is indeed different than the 99-up 4R100 with respect to TCC operation, on/off vs PWM...
The question arises, how does an E99 owner confirm what he has, if his truck was purchased used, and was possibly frankensteined with newer transmissions and PCMs?
Old Jan 23, 2014 | 10:09 PM
  #28
BadDogKuzz's Avatar
BadDogKuzz
Well I really hate to jump into this one but I do have a E99 and I built my E99 4R100 so let me say what I have and what I found to be true for me.
My truck was bone cold stock and never messed with before I bought it but to make sure that was the case with the trans I checked the plate on my trans and my 4R100 was built Aug 14 1998. And I could tell no one had ever been inside it. Down to part # on clutch disc and other things.
So it is a true E99 and it is a PWM TCC set up.
Now that is not to say there isn't any E99's with 4R100 with a Non PWM??
Honestly it wouldn't surprise me with an E99 since they are such odd *****.
Now I think this backs up what Cody said earlier about pump case part#.
This is per ATSG:
Non-PWM Pump assy (with Cast Iron coast clutch drum) F81Z-7A103-AA
Non-PWM pump assy(Stamped Steel coast clutch drum) F81Z-7A103-BA
PWM pump assy (with Stamped Steel coast clutch drum) F81Z-7A103-CA
Old Jan 23, 2014 | 10:24 PM
  #29
cleatus12r's Avatar
cleatus12r
Butt-Head
Google the part number. Easy.
Or visit your local Ford dealer. Easy.
You could also remove/rebuild/reinstall a few and see that part number on any and all 1999-2003 7.3L truck(s). I have been there more times than I care to recall.
Old Jan 23, 2014 | 10:27 PM
  #30
cleatus12r's Avatar
cleatus12r
Butt-Head
Still backing MY suspicions but I'm caving on this one since there are obviously people here with vendettas.
