lcd brightness
Old Jan 21, 2014 | 10:48 PM
boatflounder's Avatar
boatflounder
lcd brightness
is there anyway to adjust the brightness of the lcd info and nav displays. I know the light dimmer adjusts it but not in relation to the gauges, if I turn the screens down enough I can barely read the speedometer. is there a way to adjust just the screens?
thanks in advance
Old Jan 22, 2014 | 05:09 AM
2ndStroke's Avatar
2ndStroke
On the oil temp/ trans temp screen, if you push the right arrow a few times it goes black, I do that on long night road trips, dunno about the nav screen though.
Old Jan 22, 2014 | 07:04 AM
720Deere's Avatar
720Deere
No way to adjust the LCD that I know of. The navigation has its own brightness setting for both day and night. I don't remember how you get there, but in the nav mode there are settings.
Old Jan 22, 2014 | 10:27 PM
boatflounder
okay well played around some today and found you can adjust the nav display a little bit throught he settings menu, only a plus or minus of defaults. Havent driven tonight so cant say for sure if it helps or not. will probably have to go with 2nd s suggestion of the blank screen for the other screen which is fine since I can never figure out what to put there anyway.
wfedwar
Mar 12, 2018 10:01 AM
ironbender
6.7L Power Stroke Diesel
May 23, 2016 03:26 AM
sailmfast
6.4L Power Stroke Diesel
Nov 17, 2010 08:53 AM
ajorn
18
Jan 25, 2010 08:27 PM
cgl
Jul 24, 2004 11:22 PM
