Transmission temp with AE?
Old Jan 25, 2010 | 11:09 AM
ajorn's Avatar
ajorn
While waiting for my gauges I wanted to check the temp on my trans. The only setting I see on AE is for transmission fluid temperature but it is in volts...anyone know how to convert?
Old Jan 25, 2010 | 12:28 PM
jdecker88's Avatar
jdecker88
Doesn't work for our trucks all it does is either cold,operating, or your screwed atleast thats what I have always been told and it shows up on the AE the same way
Old Jan 25, 2010 | 12:49 PM
Layson's Avatar
Layson
are you sure, I can pull up trans temp on AE. Just did it yesterday.
Old Jan 25, 2010 | 01:00 PM
jdecker88's Avatar
jdecker88
Tried it on mine just did volts now mine is a 2000 it didn't really move at all and we tested it trying to get it warmed up
Old Jan 25, 2010 | 01:03 PM
Layson's Avatar
Layson
It was on a 2000. What version of AE. I think I have version 8...
Old Jan 25, 2010 | 01:10 PM
mueckster's Avatar
mueckster
I have version 8 and only saw TFT volts in the drop down menu for my 2001. Just had AE hooked up on Saturday. Conversion chart that I have in my ATSG manual is from ohms to *F. I haven't checked my Ford dvd manual for V-*F conversion chart.
Old Jan 25, 2010 | 01:17 PM
Izzy351's Avatar
Izzy351
hhmmmm... My ScanGauge reads it. I would think AE should too.
Old Jan 25, 2010 | 01:21 PM
mueckster's Avatar
mueckster
I think the AE just doesn't offer the proper conversion in its software. Just like there is coolant temp shown, but it doesn't read it properly. EOT reads fine.
Old Jan 25, 2010 | 01:25 PM
spdmpo's Avatar
spdmpo
I think it's the same type of 0-5V sending unit as any aftermarket electric temp gauge. I know I'm pulling my temp readings off the factory sender it's pretty accurate, within 5 degrees.
As for AE, couldn't say if it converts to give a temperature reading, never used it before.
Old Jan 25, 2010 | 01:50 PM
shacks87's Avatar
shacks87
I can read the TT with my AE, mines a 2000 F350. I dont know how acureit it is though.
Old Jan 25, 2010 | 02:02 PM
Izzy351's Avatar
Izzy351
Coolant temps are different -- the PCM doesn't even read them on autos. It reads fine on manuals. ScanGauge shows a number, but it's bogus.
Old Jan 25, 2010 | 02:07 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I could only read EOT, not coolent temp or trans temp.
Roland, my #3 injector is now reading 1.4 and #8 is around 7.5 . Seems to be getting better sense I changed the CPS.
Old Jan 25, 2010 | 02:45 PM
Layson's Avatar
Layson
It was slightly hotter then the trans gauge he had... LOL, sorry guys but you can read it....
Old Jan 25, 2010 | 02:46 PM
ajorn's Avatar
ajorn
After work I could post a screen shot but on a 2000 7.3 on my version of AE (have to check when I get home) I only have volts as an option....
Old Jan 25, 2010 | 04:30 PM
mueckster's Avatar
mueckster
I was working on a friend's '02 this afternoon and found that I could read TFT on it. I hooked back up to my truck and configured for an '01 and the option was available on th drop down menu. I guess I may have just overlooked it the other day. Reads the TFT fine.
