Fuel tank setup
Old Jan 21, 2014 | 07:58 PM
FordFETruck's Avatar
FordFETruck
Originally Posted by Piston Honda
Hey, did you by chance replace fuel lines? If so did you get pre bent?
Fuel lines are original on mine.
Old Jan 21, 2014 | 10:52 PM
ctubutis's Avatar
ctubutis
Here are three pages of fuel tank senders from the 1980-89 parts catalog... we are only interested in those used in the F series and these are only the kind that don't have integrated fuel pumps (the 9275)...
Here are the ones including fuel pumps (the 9H307):
Old Jan 22, 2014 | 08:27 AM
Piston Honda's Avatar
Piston Honda
Originally Posted by FordFETruck
I went through all of this with my mechanical fuel pump, 351W truck. Got mine from LMC, one was bad (it was EVERYWHERE) They sent out another one for free. This one works better. LMC was the only place I could get one for an 85-86 with no return line and the old style two pin electrical connector.
I'm not sure if mine had two or one tube. If it did have the return line where does that return line go? That should tell me which system I have. It sounds like I have the same one as you do.
Ctubutis,
Thanks for the info! I called the local ford dealership and he said that he can't get it but the part# is E5TZ-9275-G. On the list you posted that part# reads 85/86 F150/f350-- all 6 & 8 cyl exc. 460 non EFI engines so this must be the single tube. The other part# that I found looking through that list is E5TZ-9275-JA which is for 85/86 F250/F350 8 cyl 351/460 which has dual lines, so these are the two possible parts.
Old Jan 22, 2014 | 11:32 AM
FordFETruck
If you had a return line it would return to the top of the fuel tank sending unit right next to the barb for the fuel pickup.
Old Jan 22, 2014 | 12:02 PM
Piston Honda
Does it return from the carb or pump?
Old Jan 22, 2014 | 12:24 PM
ctubutis's Avatar
ctubutis
It would return from the carb.
Some of these systems had something called a Hot Fuel Handling Package, this basically keeps a steady supply of fuel flowing to the engine (be it a carb or EFI) and the excess goes back to the tank. This was to prevent vapor lock caused by fuel lines "too close to" an exhaust manifold (for example).
This truck is a 1985 which would have a feedback carb or, optionally, EFI - but only if the 6-banger or 302 AND on an F150... this is an F250 which is most likely somewhat different... depending, of course..
Simply put... are you gonna use a plain, ol' carb in what sounds like a non-factory configuration? If so, you don't need a return tube, so a sender with a single tube would be fine (this was used for decades in the past). You need to get one for the size tank you're using, the size of the hole in it (2.5" or 5.25" or something in those areas) and the correct electrical connector. You might run into differences with the locations of the, um, bent-down tabs on the flange lining up with notches in the tank (best way I can describe it quickly).
I hope you're learning to NEVER get rid of the old stuff until AFTER the new configuration is up and running....
Old Jan 22, 2014 | 01:54 PM
Franklin2's Avatar
Franklin2
Well, I found out recently they had two different return type systems. One system used electric pumps in the tanks, and this system would return from a fitting up near the carb. But they also had a mechanical pump return system, the mech pump had 3 lines coming out of it, so those would return from the pump. That is the 460 system. They have the 3 line mech pumps at the store. I don't know if the 351w return system was electric or mechanical, or could have been either like the 460's. Ford did like to change it's mind on some things didn't they?
Old Jan 22, 2014 | 02:57 PM
Piston Honda
I'm replacing the 2 barrel with a 4 barrel. I'm going to order the single outlet sending unit, worse case I'll have to return the tank if the hole is not the same size as the sending unit.
Old Jan 22, 2014 | 04:01 PM
Piston Honda
Is the ford sending unit superior to an aftermarket one from LMC?
The LMC unit is 70$. I called around and found someone who has both of the Ford OEM sending units. The two outlet unit is 170$ and the single is 235$. Could I get the cheaper two outlet unit and plug the return without any problems if I decide to go the ford route?
Old Jan 22, 2014 | 05:27 PM
Franklin2's Avatar
Franklin2
Be ready, the two port model may not fit your wiring harness plug, especially if it's a unit for a electric in-tank pump. If it's the electric pump model you will also have to modify the sending unit since you won't be using a pump. Small stuff that can be overcome, but just a warning it may need some modifications to make it work.
Old Jan 22, 2014 | 08:37 PM
ctubutis's Avatar
ctubutis
Yes, I forgot about those, I think Jim (Ardwrkntrk) posted pictures once.
The OEM sender (and pump, if equipped) is vastly superior in my experience... I will NEVER purchase a Spectra-brand unit ever again...
Old Jan 22, 2014 | 08:57 PM
FordFETruck
If you're rich, get the OEM one. I got one from LMC that was a wack job out of the box, however they sent me another one for free and it works pretty well.
Old Jan 24, 2014 | 10:42 AM
  #28
Piston Honda
Well, I'm not rich, but I found it a little cheaper at 189$ and ordered it. Thanks for the help guys.
Old Jan 24, 2014 | 11:10 AM
  #29
FordFETruck
Good deal!
Old Jan 28, 2014 | 03:47 PM
  #30
highoctane74's Avatar
highoctane74
There is a TON of options for 85. Ford couldn't help me here. When I was building my truck it had the small hole fuel tank. The parts guy said 85 was a change over year, so it could have came with anything. I ended up replacing it with an aftermarket Spectre tank and LMC sender, it has been good so far. I have a 4 barrel carb and went with a non return style.
wdhille
18
Jun 22, 2010 03:06 PM
hivolt5.0
Oct 23, 2008 01:38 PM
doc54
13
Jun 8, 2008 08:13 PM
78blueford
Mar 12, 2003 11:21 AM
