fuel tank sending unit
Have any of you all used the fuel tank sending unit sold by LMC? I was checking the ohm readings on mine to make sure the gauge and the sending unit are matched and I was getting some whacky readings. I ended up pulling the cover off and ohming the wire winding and got a much better reading. Hopefully it will work like it is supposed too once it is all installed and fuel is in the tank.
Received 1,344 Likes
on
