Sponsored by: Real Truck
Daytime Running Lights Question
Old Jan 21, 2014 | 11:19 AM
3504x4's Avatar
3504x4
I have a 2003 F250 V10 Crew cab. I bought it about two years ago. The truck came with daytime running lights. I noticed that when I had the selector switch all the way to the left the DRLs where activated. The dash lights were not lit until the ambient light got darker.
Now the dash lights are on all the time and it makes my stereo and overhead temperature display dimmer. Making it hard for me to see the temperature during the day. The only way to brighten up my stereo and overhead console is to have the selector switch on the off position.
Is this correct or is there something wrong with my DRLs?
Old Jan 21, 2014 | 12:17 PM
meborder's Avatar
meborder
i don't think too many people state-side have DRL's, so maybe someone from up north can help more.
do you have automatic headlights?
it sounds like maybe the automatic headlights are turning on when they shouldn't be.
just a thought.
Old Jan 21, 2014 | 12:22 PM
3504x4's Avatar
3504x4
Yea that's what I think. I called the ford dealer in town and the lady was very helpful. I wonder if there's like an ambient light sensor that's not working correctly
Old Jan 21, 2014 | 12:25 PM
3504x4's Avatar
3504x4
I'll double check. I may have automatic lights instead of DRLs
Old Jan 21, 2014 | 02:48 PM
asdrew's Avatar
asdrew
It sounds like your headlights are coming on rather than DRL.
I have DRL module I ordered and installed on my last 3 Florida crew cab trucks ('00 Dually Diesel, '02 250 v10, '05 250 v10) and it puts the headlamps (only) on after 45 secs or something at a lower percentage of light and does not dim any panel lights or turn on any other lamps.
I keep the switch in auto position and if the lights go on either by the sensor or manually, the DRL module shuts off.
The DRL module is very particular about which wires are connected to what, so if you indeed have one it might be wired wrong or it may have gone bad.
Old Jan 23, 2014 | 03:29 PM
GregsSD's Avatar
GregsSD
If your truck has auto headlights, then the sensor is at the front of the dash under the center of the windshield. Make sure you don't have anything covering it or that it has any dirt on it.
Old Jan 23, 2014 | 09:03 PM
3504x4's Avatar
3504x4
I thought that was for the compass/temperature readings. Ill check it out. Thanks
Old Jan 24, 2014 | 12:37 PM
thomabb's Avatar
thomabb
If your light switch has more than 3 positions (off, marker, and headlight), you have auto lamps. Another way to tell, DRLs are ONLY the headlights. If your markers and tail lights are on, you have auto lamps.
wharrell
Mar 20, 2018 10:31 AM
6.9idiatsturbo
18
Aug 15, 2016 05:54 PM
rpenterics
Feb 17, 2014 08:27 AM
ebaugh90
May 8, 2009 12:45 PM
whitesdford
Jul 26, 2008 11:08 AM
