Headlight help
Old Jan 21, 2014 | 09:06 AM
YoungGunSpencer's Avatar
YoungGunSpencer
Headlight help
I'm trying to find a l.e.d replacement headlight anyone know a definite source?All I found were these --
http://www.carparts.com/details/Ford...Fa47MgodkWQA5g
1978 f150 ranger
Old Jan 21, 2014 | 09:38 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Hello Kentucky....That is a direct replacement OE style bulb. It not like new cars to swap in LED bulbs. You will need some relays and such....
Using the "Advanced Search" option will give you all kinds of help, and threads to read. You have to do some leg work for it ok?
Truck Parts and Truck Accessories
Here is a great idea to go with it, the Heavy duty harness.
Old Jan 21, 2014 | 10:25 AM
YoungGunSpencer
Its a good thing I have to rewire my truck anyways, but I'm trying to find a whole replacement -lens,housing, everything. I know its not just a bulb switch...
Old Jan 21, 2014 | 10:43 AM
AK FORD GUY's Avatar
AK FORD GUY
A set of E-Code Cibie Housings and these L.E.D. Bulbs should get you what you are looking for.
Article on L.E.D. H4 Bulbs. (I know it's not a Ford, but just read about the bulbs...)
Cree LED H4 headlight bulbs (2000lm) - MX-5 Miata Forum
L.E.D. Bulb Kit:
http://www.vleds.com/shop-bulb-numbe...xa-2000lm.html
Round Housings:
Amazon.com: Cibie 082440 Light Unit: Automotive Amazon.com: Cibie 082440 Light Unit: Automotive
Rectangular Housings:
Amazon.com: Hella 200mm Rectangular E Code H4 Halogen Replacement Headlight Kit with Standard 60/55W H4 Bulbs: Automotive Amazon.com: Hella 200mm Rectangular E Code H4 Halogen Replacement Headlight Kit with Standard 60/55W H4 Bulbs: Automotive
Old Jan 21, 2014 | 10:45 AM
77&79F250's Avatar
77&79F250
I thought I answered your question exactly like you asked it.
Why didn't you say "I'm trying to find a whole replacement -lens,housing, everything." ? The first time around?
https://www.ford-trucks.com/forums/1...onversion.html
https://www.ford-trucks.com/forums/1...rades-hid.html
https://www.ford-trucks.com/forums/9...l#post11110184
1973–1979 Ford F150 Projector Headlights By ProTuningLab
Xenon HID Conversion Kit 6000K 8000K 10,000K 12,000K By ProTuningLab
1961-79 Ford Truck & Bronco LED Gauge Light Conversion Kits - HiPo Parts Garage (Just in case you need this too)
Old Jan 21, 2014 | 10:51 AM
YoungGunSpencer
@ak - not a bad idea at all
@77 - I thought headlight would imply the entire set up, but its ok ill know to 100% next time. thank you for the links
Old Jan 21, 2014 | 10:55 AM
77&79F250's Avatar
77&79F250
No worries, I read headlight I think headlight. I found them links in a 5 sec google search.
Now I have some reading to do also....make sure to post up what you find and what works for you.
We all like opinions, it saves us money.
Old Jan 21, 2014 | 11:02 AM
YoungGunSpencer
money saver tip #1 if you buy a truck in the summer don't forget to check that baby for antifreeze!! I got lucky and I had barley any and it was 1 degree F. for a couple days before I could get any in it.
Old Jan 21, 2014 | 11:04 AM
77&79F250's Avatar
77&79F250
Go here and go to post reply #10 and click on the 1st link.
Or here it is for you.
Illuminator Headlight Harness - WILD HORSES Full Size Ford Bronco Parts
Brandon606
Apr 27, 2019 08:37 AM
IndySilverAnny
1997 - 2003 F150
Jan 31, 2019 12:53 PM
BIGTRUCKBIGRV
Jan 26, 2017 12:23 PM
Icthus in AK
Jan 21, 2015 11:32 PM
HookedOnFuel
Nov 26, 2007 10:47 PM
