Sponsored by: Real Truck
LED Headlight Lens Replacement: Thoughts?
Old Jan 20, 2015 | 09:08 AM
Icthus in AK's Avatar
Icthus in AK
A local shop will, for right around $300, install these Racesport LED headlights in my OEM bezel.
http://www.racesportinc.com/E-Shop/p/4688/7x6-led-conversion-lens-pair
Curious if anyone has knowledge as to whether LED replacements (not just an LED bulb in the factory reflector but a replacement headlight unit) are effective. I'm not looking to try to make my 2013 F250 PSD look "cool" like with Recon drop-in units; I want to see in the Alaskan dark without adding gymnasium-style lamps on a bumper rack. I see plenty of semi trucks running these here so there must be something to them. Thoughts?
Old Jan 20, 2015 | 09:51 AM
moymurfs's Avatar
moymurfs
Another option is Hella Vision Plus conversions http://www.myhellalights.com/index.p...sion-headlamp/
They are pretty good. You can then use a replaceable bulb in them either halogen, led or hid. They are designed for halogens, I don't know what the light from a led or hid bulb would actually do but they would fit. One of the models IS DOT approved if that's a hang-up.
Old Jan 20, 2015 | 05:55 PM
Icthus in AK
Anyone anyone Bueller?
Old Jan 21, 2015 | 01:04 AM
scotttahoe's Avatar
scotttahoe
If you live in the snow or ice the headlights will never de-ice themselves as there is no heat from an LED bulb. Just a heads up.
Old Jan 21, 2015 | 09:13 AM
rjfetz1's Avatar
rjfetz1
If you see that many truckers with them then get them. You sure they are LED and not projectors? I see many truckers with projectors not LED's
I have and recommend retrofit projectors from Blackbirdlightingsolutions.com
Bright as bright can be.
Old Jan 21, 2015 | 07:11 PM
Icthus in AK
Yes, semi's with LED headlight units and they don't snow-cover. Spoke with several fuel-haulers who travel North past Fairbanks and they've never had issues.
Old Jan 21, 2015 | 11:32 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Yes, I have seen projectors with LEDs.
Yes, they work.
Sometimes, they have issues de-icing. There are mixed reports
Juanito
Aug 19, 2020 07:17 AM
WW26Red
2015 + Expedition & Navigator
Apr 16, 2020 07:34 PM
BIGTRUCKBIGRV
Jan 26, 2017 12:23 PM
HookedOnFuel
Nov 26, 2007 10:47 PM
rabbithutch
Sep 27, 2005 10:32 AM
