headlights flickering
Old Jan 17, 2014 | 10:25 AM
300sixnick's Avatar
300sixnick
My head lights are flickering both of them are flickering at the same time. When the head lights flicker off the side lights come on for a second. I replaced the head light switch it seemed to hold it for longer than it did before ( like 5 seconds longer) than they started flickering again. 1979 ford f250 300 six rw drive custom mostly original, don't think any wiring has been tampered with, anyone know where the head light relay is? Or if there's anything else you think could be the problem? Thanks
Old Jan 17, 2014 | 10:32 AM
fmc400's Avatar
fmc400
MSEE
There's no headlight relay.
Measure the voltage across the battery posts with the engine idling, and report your results and note any fluctuations in voltage. Your next post needs a number in it.
Old Jan 17, 2014 | 11:09 AM
79FordBlake's Avatar
79FordBlake
For me its usually been the headlight switch or the dimmer switch causing the problem. Good idea to still do as FMC400 suggested.
Wont hurt to clean off all connections also.
Old Jan 17, 2014 | 03:07 PM
jsutton's Avatar
jsutton
For me it was the positive wire for the front parking light above the drivers side headlight. There was a bare spot in the insulation of the wire at the core support and when the bare spot hit the metal it would cut the lights off. Just something else to check for.
Old Jan 17, 2014 | 04:05 PM
rsfabrication's Avatar
rsfabrication
I had that happen while sitting in an hour long traffic jam my engine was fine but there was so much saturating heat. I honestly think the headlight switch got hot. Once I started moving good again issue went away.
460/c6 / longtube under the cab headers / pulling a 18ft car trailer. Was on my way to pick up my other truck that broke down on my Dad returning from out of state.
Old Jan 17, 2014 | 04:22 PM
300sixnick's Avatar
300sixnick
I heard some times the relays in the old light switches sometimes can't take the full load of all the running lights so I offed all the side lighting onto blinkers and brakes, (was planning on it anyways the side lights didn't work at all before) and I turned the head lights back on and they worked for about 15 seconds before they started flickering again I checked the voltage across the battery it looks fine, guess I'm off for a voltage regulator tomorrow! I checked all the hidden wiring it looks fine, is the light dimmer switch you are talking about just done by turning the the head light switch button thing? Thankseveryone
Old Jan 17, 2014 | 04:30 PM
jsutton's Avatar
jsutton
The dimmer switch in on the floor board, operated with your left foot.
Old Jan 17, 2014 | 04:32 PM
300sixnick's Avatar
300sixnick
Oh the high beam switch. But everytime the lights flicker I can hear a noise coming from the headlight switch and it is brand new I replaced it today
Old Jan 17, 2014 | 05:29 PM
Blue and White's Avatar
Blue and White
I believe the switch has a breaker that may be making noise as its about to trip. I'm guessing there is a short in the wiring someplace and suggest visual inspection of all wires feeding the lights.
Old Jan 17, 2014 | 05:43 PM
fmc400's Avatar
fmc400
MSEE
What does "looks fine" mean? I asked for a number.
How do you know you know it's the regulator itself?
OK, that changes things. This has nothing to do with the voltage regulator. That's why I stress that you follow my instructions and take measurements rather than randomly replace parts.
Old Jan 17, 2014 | 06:16 PM
300sixnick's Avatar
300sixnick
Voltage read 13.76
Old Jan 17, 2014 | 08:37 PM
brian1080's Avatar
brian1080
You should also be more specific on what it's doing.
Is it flickering as in on/off or is it flickering as in pulsing?
Mine pulse when the truck is running, my battery is weak and my alt is going out. I'm planning on fixing these with the 3g upgrade and a different battery as soon as I can get to the junkyard.
Old Jan 18, 2014 | 05:11 PM
300sixnick's Avatar
300sixnick
What do you mean by pulsing?
Old Jan 18, 2014 | 06:45 PM
300sixnick's Avatar
300sixnick
My lights flicker at the same time I hear a click coming from the light switch, I think It is a breaker or something but I don't know why it's going off
Old Jan 18, 2014 | 07:08 PM
devino246's Avatar
devino246
There's a breaker built into the headlight switch. You've got too much current draw downstream. Listen to fmc; you won't find a much more knowledgeable guy when it comes to automotive electrical systems.
