Carburetor spacer
Old Jan 19, 2014 | 12:20 PM
lemasters f100's Avatar
lemasters f100
Carburetor spacer
Is the spacer between the intake manifold and the carburetor really necessary? It's part number 48-3889 on Truck Parts & Truck Accessories for Chevy, GMC, Ford & Dodge Trucks | LMCTruck.com
Old Jan 19, 2014 | 12:22 PM
lemasters f100
1978 f250 ford 400
Old Jan 19, 2014 | 12:23 PM
Dave145's Avatar
Dave145
Essentially. The idea is to raise the carb off the manifold to help alleviate fuel boiling issues, as it keeps the carb a bit cooler.
Old Jan 19, 2014 | 12:37 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on the heat xfer and possible fuel boiling. Its is made of phonolic material for a reason.
The stock intake manifold is cast and will get hot and that heat can transfer to the fuel lines/carb, The heat build can boil the fuel before it has a chance to get to the carb.
Some say a old trick is to put a wooden close pin to prevent it....urban legend.
https://www.ford-trucks.com/forums/1...ue-how-to.html
Old Jan 19, 2014 | 01:03 PM
gatorfor88's Avatar
gatorfor88
The clothes pin trick actually works. I use it myself and have used it since about 77. I owned a 75 mustang 2 with a 351w and she would not run more than 20 minutes in summer before vapor locking. About 5 clothespins solved that. I have 4 on my 78 Bronco now.
Old Jan 19, 2014 | 02:25 PM
lemasters f100
I have a edelbrock intake I'm wanting to put on would I still need it?
Old Jan 19, 2014 | 02:33 PM
jason77F250's Avatar
jason77F250
Most auto parts stores sell them.
Old Jan 19, 2014 | 02:48 PM
Dave145's Avatar
Dave145
Yes you will need it.
Old Jan 19, 2014 | 03:04 PM
gatorfor88's Avatar
gatorfor88
The spacer not only insulates carb from heat, it also helps bottom end torque. Dont know if it is seat of the pants noticeable but it is measurable on dyno. Actually 1 of the cheapest performance upgrades you can do.
Jpegg01
May 25, 2018 10:11 PM
Fordguy_1970
Apr 1, 2010 07:35 AM
aussie1
Nov 8, 2006 09:18 AM
tractoman
May 26, 2006 02:53 PM
BLaCkSiLo
Mar 28, 2004 11:24 PM
