Correct Carb Spacer?
Old Mar 25, 2004 | 01:05 PM
BLaCkSiLo's Avatar
BLaCkSiLo
Cool Correct Carb Spacer?
hey all, i'm going to purchase a weiand stealth intake and a edelbrock 750 carb for the 460, and i was wondering what carb spacer i might need, if i need one at all... i've heard that if you space the carb, the mixture is cooler and helps with detonation?
but anyway, thanks for help guys... any info would be nice.
Old Mar 25, 2004 | 08:03 PM
doccamel's Avatar
doccamel
I was always taught that spacing will increase High rpm power slighty but take a little torque in the process. If you get the right type of spacer it could theoreticly help keep the fuel cooler by slowing the heat transfer from the intake.
Any other opinions?
Old Mar 26, 2004 | 10:39 PM
beeboy's Avatar
beeboy
If you use a plastic or phenolic spacer, it will help to insulate the carb from the intake manifold heat. 1" is usually recommended
Old Mar 27, 2004 | 10:52 PM
LxMan1's Avatar
LxMan1
1" 4-hole spacer is what you need.
Old Mar 28, 2004 | 11:24 PM
BLaCkSiLo's Avatar
BLaCkSiLo
sweet, thanks guys, i'll go ahead with that
