Thanks,would you replace the eaton fittings as well,do they go bad?
I posted a link earlier in this tread for the rebuild kit. Actually they sell a new updated fitting that has an oring on the outside of fitting to keep water, dirt and whatever out of the fitting. The ones on the head are not to costly but I think the new updated ones that go into the hpop are like $29 each.
Do they go bad yes they do but not at a super high rate of failing. But in my book any failure can leave you dead on the side of the road same as a bad line can and will.
